Iphone 4s memory problem
  • sogaro
    • Feb 2010
    • 1875
    I have a 4S 16Gb and have issues with the memoty recently. Been tweaking with it a lot in recent times so dont really know what i did that got me where i am. I am having about 8.5GB of "Other" used and that has almost taken up my space. How do i access the files tagged "OTHER" in iTunes or any other similar applications.
    Sent from iPhone 16 Pro Max
  • johnboy1974
    • 3418
    Have you jail broken your device if so it may be stuff from cydia. If you do a full restore through iTunes it should clear it and only put back on what's in the iTunes library.
    Sent from my iPad using Tapatalk HD
    • sogaro
      • Feb 2010
      • 1875
      Checking through iFile this morning i saw a file 5GB and its called syslog under the directory /var/log
      Can i delete this?
      • johnboy1974
        • 3418
        Can i delete this?
        Sounds like system log I wouldn't touch it mate I would restore through iTunes and then rejailbreak.
        • sogaro
          • Feb 2010
          • 1875
          Wrong mate, i copied it to my system and then deleted, am good to go , no qualms whatsoever. It even re-adds it with 0bytes after i rebooted.
          Got this afterwards; iPhone memory full by 'other' that wasn't there before, how do it get it back normal? - MacRumors Forums
