Still not working after new digitizer???
  • wiseman
    • Feb 2010
    • 1220
    Changed the digitizer on my Iphone 3g 16g, and it still wants to have a mind of its own, doing all the usual symptoms that would make you think it was the digitizer faulty,
    you need to touch a lower part of the screen if you want to open something higher etc...
    new motherboard? or can it be fixed??
  • wiseman
    • Feb 2010
    • 1220
    help......:-(
    • wiseman
      • Feb 2010
      • 1220
      anyone?????????
      • Canker_Canison
        • May 2010
        • 3905
        Did this ever get wet?
        Check around the connectors for the LCD & Digitizer for any sign of contamination or white marks. If you find some, clean it down with a toothbrush & some IPA (Isopropyl alcohol). Allow it to completely dry before putting the connectors back in.
        Canker
        [COLOR=Green]
        • biffo1
          • 420
          did you replace just the digitizer or lcd Screen as well ive repaired a few iphones all with success , if you have the same problem as u have now that u had before maybe its not the digitizer ?
          are the 3 ribbons connected correctly
          [CENTERsigpic[/CENTER]
          • plasma533
            • Feb 2010
            • 566
            carried out a calibration of the touchscreen?
            • wiseman
              • Feb 2010
              • 1220
              no will try this
              • wiseman
                • Feb 2010
                • 1220
                how do you do this?
                • Canker_Canison
                  • May 2010
                  • 3905
                  As far as I'm aware there is no calibration function for the Iphone.
                  If you are getting exactly the same problem I would be looking for damaged pins on the board connector or restoring the firmware.
                  Canker
                  [COLOR=Green]
                  • wiseman
                    • Feb 2010
                    • 1220
                    Tried the firmware upgrade twice on the phone now to no success, it appears to be ribbon connectors through out the iphone, i tried cleaning up the connections to the digitizer with alcohol... im really stuck , think it needs a new motherboard
                    • fijiman
                      • Oct 2010
                      • 976
                      It's time to take a hammer to it ......I feeling your frustration...
                      • wiseman
                        • Feb 2010
                        • 1220
                        ~~~~in pain in the tits
                        • Canker_Canison
                          • May 2010
                          • 3905
                          When you put it back together, did the ribbon ever get caught?
                          Even the slightest knick or hard crease in a ribbon can ~~~~ it.
                          Canker
                          [COLOR=Green]
                          • wiseman
                            • Feb 2010
                            • 1220
                            i very much doubt i did , was extremlly carefull, and anyway its still doing the exact same problem i had to begin with
