hi im having a problem restoring iphone 3gs 8gb it keeps getting an itunes error 21 and also will not enter recovery mode its stuck in dfu mode, and wont re-boot out of it has anyone got any ideas on what to do to help me please thanks emma
itunes error 21
Were you trying to install custom firmware,jailbreak?is there anything on screen?
Recovery mode has a picture that says connect to iTunes. In DFU mode, the iPhone screen backlight is not even on and the display is blank. If you have anything on your display you are not in DFU mode. -
Try again make sure plugged in and sound on pc and iPhone ,then keep trying to dfu unplugging and back in and so on
Attach the phone to the pc
Turn the phone off
Hold power and home together for *exactly* 10 seconds
Release power but keep holding home until the pc beeps as a USB device is recognized.
At no point will the display come on. Now your restore should work.
Having problems? Try adjusting the 10 seconds to be slightly less like 9 seconds, then 8, then 7. It***8217;s a tricky timing but you will eventually get it.
Also when you do get it u have to restore to a stock(real firmware) first,before jb with customLast edited by mickydibble; 1 March, 2011, 22:40.Comment
ive tried everything its in dfu mode when i try to restore using itunes it gives error 21 and restarts with either a white screen or in dfu mode. i tried red snow and it goes right through and then does the end part ten says its re starting but it ends up back in dfu mode......im stuck now on what i can try grrrrComment
this is a bit of a long shot but i kinda had the same problem when using blackrain. stuck in dfu. after 4 days of searching i found the answer to my problem
first make a new windows user on your pc/laptop then install itunes after logging in as the new user. when done conect iphone and it instantly tells you you need to restore. job done let me no how you gets onComment
Think you should try ireb from here iH8sn0w.com | Jailbreak your iPod touches and iPhones and also try tiny umbrella The Firmware Umbrella - TinyUmbrella also if it's saying recovery then suppose your not in dfu properly anyway good luck in what you decideComment
