Where can I get drivers for Compaq Presario
drivers needed
ha ha use googleMY POSTS AND ANY PM`S ARE PURELY FOR EDUCATIONAL AND LEARNING PURPOSES
I AM FULLY RESPONSIBLE FOR MY OWN POSTS, MY POSTS ARE NOT CONDONED, MODERATED OR AUTHORISED BY ANY MEMBER OF STAFF ON THIS SITE AND I TAKE FULL RESPONSIBILITY FOR ANY CONTENT CONTAINED IN MY POSTS OR LINKED TO EXTERNALLY.Comment
Ok, at least which model/operating system would have helped more and ofc posting in the right section.
The most ideal situation would be backup your current drivers, assuming you are installing the same os, you could do this using a tool like -failing that install the operating system you intend the machine to run.Code:http://sourceforge.net/projects/drvback/
then downloadThis will also update any older drivers you may have.Code:http://drp.su/
If your still stuck more info the right section, will probably get noticed more and get you a response you can work with
