help please for newbie to ipod touch want to crach it
  • pjtaff
    • 212
    hi i have a ipod touch 32gb i think its a 3rd gen tried to find the firmware on it but cant but what i did find is
    version 3.1.2 (7d11)
    really want to know what is the best method to hack the ipod keep reading differnet methods and im getting confused
    also once i have hacked how do i get and instal apps, games on the ipod
    and can itunes find out once i reconnect my ipod to the computer
    so please could you help me to
    1. idiots guide to hack ipod
    2.where and how to download apps
    3. how to install apps
    4.what should i do and not do to my ipod after hack (ie settings connect to itunes< update or anything else)
    many thanks in advance for any help
    pjtaf
  • djskynet
    • Feb 2010
    • 115
    jailbreak
    two options here for you. spirit wich can be downloaded from the net (google it)
    or the other that is even eayser. open safari on youe ipod. go to jailbreakme.com and follow the prompt. easy as a poke in the eye
    you can still connect to itunes but if you update you will loose the jailbreak and it will be hard (if not impossable) to get back.
    when you do jailbreak and run cidya (will install itself when you jailbreak) it will ask you if you want to 'make your life easyer' do it. it will help if for any reason you loose your jailbreak. post back when you jailbreak and ill tell you how to get your apps ffor you.
    all the best
    a slug is just a homeless snail
    • pjtaff
      • 212
      right m8 done all that and all ok what is the best way to get apps and can i get any music also
      thanks very much for your help
      • mickydibble
        • 2166
        go to your sources in cydia find/search "installous" dl apps,then find "mxtube" dl this u-ttube style music vids etc.etc..
        ps... think u need to get a app from itunes first before installous
        • djskynet
          • Feb 2010
          • 115
          in cidya go to manage then sources then press edit (top right corner) then add (top left corner) then type in cydia.hackulo.us and add the source. ignore the warning (add anyway) install appsync for whatever your ios is. then hackulous security (importaint) then installous. you can find almost any app from there. have fun. if you have any other questions ask away. ill answer them if i can. hope this helps :-)
          • pjtaff
            • 212
            so could i download music from anywhere to put on my ipod or is it just games and apps, i know i could download onto my computer and then transfer to the ipod but could i access and download direct from the ipod
            many thanks for all your help
            taf
            • smirnoff_rules
              • 8603
              l use CopyTransManager its free and does the same as itune but u just drag mp3's in
              • pjtaff
                • 212
                sorrry to sound thick but do i download that onto my ipod and if so how will i be able to get music onto the ipod from this can i just download music straight to the ipod off the net
                • smirnoff_rules
                  • 8603
                  no . plug ipod in and use pc to transfer files
                  • pjtaff
                    • 212
                    ok m8 thanks for that so is there no way of downloading music straight to your ipod
                    • smirnoff_rules
                      • 8603
                      no m8 .. l wish
                      • pjtaff
                        • 212
                        ok m8 thought not but things move so fast that you never know,
                        one other thing if you dont mind is when i find a app or game it gives me a big list of links to download the app from is there any 1's i should avoid or are they all ok
                        • smirnoff_rules
                          • 8603
                          no m8 just download the latest ones
                          • pjtaff
                            • 212
                            thanks for that m8 your a star
                            • smirnoff_rules
                              • 8603
                              u can add 100 itunes app but u can only use on wifi/3g
