acecard2i
  • starling
    • 89
    acecard2i
    clone acecard just loaded firmware 1.8.6
    got this on screen
    maynot be genuine card please contact vendor
    please help me out
  • barrowmanandrew
    • 3427
    where did you get the card from?
    whats the web address on the card?
    • starling
      • 89
      r4i-r4i.co.uk
      • barrowmanandrew
        • 3427
        what is the web addy on the card?
        are you sure its a fake card?
        format the sd card
        Digital Kaos - Downloads - sd formatting tool
        download firmware from here.
        Digital Kaos - Downloads - akaio 1.8.6 (acecards)
        extract the files and copy _aio folder and akmenu file to root of sd card....
        • starling
          • 89
          no still nuthing so i put 1.6 on and its fine
          • barrowmanandrew
            • 3427
            seems to be alot of fake acekards about now, new ones have a holographic stivcker on the back with a security code now.
            you can check to see if your card is fake or not....
            Acekard Anti-Counterfeit Code Check
            • starling
              • 89
              no sticker on the back
              • starling
                • 89
                put games on its workin for a little then goes off
                • barrowmanandrew
                  • 3427
                  i would try it with another micro sd card with the 1.8.6a firmware.
                  if it comes up fake again, then i would contact the supplier and try for a refund.....
                  you will get a proper acekard from here...
                  Acekard 2i 3DS | Acekard 3DS | AK2i 3DS | AK 3DS | Buy Acekard 2i 1.4.1 | Acekard 2 i | Ace kard | Acekard 2i Firmware
                  • starling
                    • 89
                    but had it working with games but now not workin
                    • barrowmanandrew
                      • 3427
                      yes,
                      this suggests a problem with sd card.
                      it is recommended to use a formatting tool when formatting sd cards for use in gamecarts.
                      also make sure you don't fill you sd card right up, you need to leave room for sav files.
                      allso you mentioned earlier that the card showed up us a fake , i'd be more concerned about this...
                      have a look here.
                      its give you a couple of tips on how to detect fakes by the looking at the casing......
