hi, downloaded a few nds roms but after extraction im left with a "nero discSpan compilation file" instead of a nds file, (think this due to the fact that i have nero multimedia centre installed on my pc), is there anyway of getting a nds file after extraction instead of this, i dont want to un-install nero as i use it quite often, ive tried to get the file by going through nero but get a "unexpected file format" message. or is there a way to change the file format. thank you
help with nds roms after extraction, please
Tags: None
im not sure what you mean,
with nero installed the file icon changes,
but the file still ends .nds and when you put it onto your sd card it works just the same...... -
hi, the icon does change but the file no longer ends in nds, tried it in my ds and games wont load. thanks for your replyComment
hi m8. try extractin to a new folder, then open , you might find as many as 6 files in there. just get rid of rubbish, ie jpegs, then put the 1 good file on to ds/dsi. hope this helps. i always extract to a folder named ds or dsi or some such . easy to monitor as well.den
forget messin with nero. leave as is. just copy/paste
