folders are shortcuts
  • dingledangle
    • 528
    hey guys,i dont know if im posting this in right place but here goes,ive taken the memory card out of my r4i gold card to put more games on it,but when the drive opens up in windows all of the folders are shortcuts,and when i put the card back into the dsi xl no games show up at all now,any help much appreciated.
  • barrowmanandrew
    • 3427
    sounds like your sd card is ~~~~ed or needing formatting...
    i would back up your card , format it and copy the stuff back...
    • dingledangle
      • 528
      cheerz barrow,i had to format the card and find the right firmware,cheerz
      • lizterry
        • Oct 2011
        Well, just came across this post. As a user who suffered similar problem with USB flash drive before. Here is the solution:
        First things first - DO NOT format the drive right away as it may make things worse.
        Then check whether the folders are in hidden mode.
        Click on "Start" -->Run-->type cmd and click on OK.
        Here I assume your memory card as G:
        Enter this command: attrib -h -r -s /s /d g:\*.* (replace the letter g with your memory card letter showed under "My Computer").
        Then check if your real files will be showed.
        If your files won't show. You have to use some strong anti-virus or anti-malware programs to eliminate the virus or trojans. If still won't help, learn more from this article:
        fix folders become shortcuts - an article gives very detailed fix solution steps. It should help you out.
        Hope it helps, best regards.
