Acekard 2i Not working?
  • SpiralTrance
    • May 2011
    • 32
    #16
    Originally posted by barrowmanandrew
    hi m8,
    ive had a look at your video, the only diffrence i see to your setup is the games been in folders,.
    just to make absolutely sure:
    format your sd card again.
    download this rar file and extract it straight to your sd card.
    do not put anything into folder, just leave it as it is.....
    this is firmware and a couple of roms from my sd card, an older one and a newer one,
    just to make sure m8.....
    let us know how you get on...
    will do thanks m8
    • jamie0691
      • May 2011
      #17
      Originally posted by SpiralTrance
      will do thanks m8
      Just out of interest where did you get yours from?
      • Fellianis Wig
        • 427
        #18
        If youre after one google gamwrecked thats where I got mine couldn't fault them.
        • SpiralTrance
          • May 2011
          • 32
          #19
          www.r4i-gold.co.uk
          had an email back from them saying they'll set up an RMA for me.
          Though they've asked for two more photos of tha card though to see if it's been there's been any damage to the card. My camera is very old and I can't clear shots of the card though so I don't know how to get any clearer shots than I already have.
          Acekard 1
          Acekard 2
          Acekard 3
          Acekard 4
          • Taylore
            • Nov 2010
            • 22
            #20
            Acekard 2i no longer booting
            I recently bought an for my DSi, and it was working fine patched with the Dorasu 3DS patch. Then the DSi forced me to update whilst the acekard was inside the DSi, and since then it always gives me the error screen after booting the card from the menu. I've tried reformatting the MicroSD with the Panasonic formatter and I've tried flashing the cart with the Alex Rider patch but nothing seems to have any effect on the end result. Have I ruined the card or is there a fix for this?
            Last edited by gmb45; 10 June, 2011, 15:26. Reason: he likes the volumerates site hmmmm
            • SpiralTrance
              • May 2011
              • 32
              #21
              Originally posted by Taylore
              I recently bought anfor my DSi, and it was working fine patched with the Dorasu 3DS patch. Then the DSi forced me to update whilst the acekard was inside the DSi, and since then it always gives me the error screen after booting the card from the menu. I've tried reformatting the MicroSD with the Panasonic formatter and I've tried flashing the cart with the Alex Rider patch but nothing seems to have any effect on the end result. Have I ruined the card or is there a fix for this?
              The card should still work it's just your DS will no longer run that card. I think it would illegal for Nintendo to brick your card.
              • barrowmanandrew
                • 3427
                #22
                the 1.4.2 firmware blocks acekards atm.
                your card will play fine on an older console.
                there is a fix for this, but acekard arn't releasing it until futher testing.....
                Acekard | AK | AK+ | AK2 | AK RPG | AK2i | Acekard 2i | Acekard 2| NDS Flash Cart | www.acekard.com | Acekard official site
                • Katherine5
                  • May 2011
                  • 47
                  #23
                  but..
                  I recently bought an acekard 2i for my DSi, and it was working fine patched with the Dorasu 3DS patch. Then the DSi forced me to update whilst the acekard was inside the DSi, and since then it always gives me the error screen after booting the card from the menu. I've tried reformatting the MicroSD with the Panasonic formatter and I've tried flashing the cart with the Alex Rider patch but nothing seems to have any effect on the end result. Have I ruined the card or is there a fix for this?
                  U can test, and will play fine on an older console
                  Bcz, mine bought from this is OK,,,works well...
                  In the pursuit of something always!
                  • Fellianis Wig
                    • 427
                    #24
                    I wonder if its anything to do with the new 3ds update coming
                    • kfan
                      • May 2011
                      #25
                      My acekard shows up as "Dorasu" in the DS console too, but it's giving an error when I try to open it. How can you tell if this is because the firmware is blocking the acekard, or if I did something wrong when loading AKAIO on the SD card?
                      • barrowmanandrew
                        • 3427
                        #26
                        thats what it should show up as m8,
                        i take you are using a dsi, which version firmware is the dsi on?
                        to check:
                        1: start up console without a gamecard in.
                        2. press ettings (spanner icon)
                        3. look at bottom right of TOP screen, your firmware version should be displayed there. either 1.4 or 1.4.1 or 1.4.2
                        • kfan
                          • May 2011
                          #27
                          Ah, ok, it says "1.4.2U". I take it this means the firmware is blocking my acekard? That's too bad...I don't have a DSLite handy to update it. Guess I'll have to ask around to see if anyone has one I can borrow...
                          • barrowmanandrew
                            • 3427
                            #28
                            you cant update it just yet,
                            the acekard 1.4.2 update hasn't been released yet....
                            • kfan
                              • May 2011
                              #29
                              Oops, I thought I found an update at another site, but I guess that was unofficial?
                              (Sorry for all the questions and thanks for the help! I'm not really familiar with the DSi, but I'm trying to get this thing set up for my little bro...)
                              • barrowmanandrew
                                • 3427
                                #30
                                it must be m8,
                                don't use it,
                                here is the official site page with the news on it...
