R4 and 3ds: major, MAJOR issues -- PLEASE help!
  • superasian
    • Jan 2012
    • 9
    Hey guys, sorry if I'm being repetitive; I know this is probably a hot topic with the new 3.0.0.6 update. Apologizing in advance for the lengthy post -- just wanted to make sure I got everything in here! :
    I'm relatively new to the whole flash cart and r4i. I managed to successfully set the card up and play games on it when I first purchased it back in september. I bought my 3DS maybe a week or two after it was first released and hadn't updated it until literally an hour or so ago. HOWEVER, the for the past 2 days STRAIGHT I've been trying to figure out some weird kink that I can't really classify..
    It started off with me trying to run the new Mario 3d land game. I hadn't known that no existing flash carts yet can run 3ds games so i basically wasted a whole 2 days of my life trying to figure out why i couldn't get the game working before I found this out. So I was just like "eff it" and found a dozen or so awesome DS games to keep myself busy.. Then came even more problems.
    The games downloaded all right and their icons show up and everything, but when I click the game to play it, it goes to the "loading?" screen and stays there. I tried waiting a few minutes, but I didn't think it was a lagging problem because I've been playing Pokemon White for the last few months without a hitch/lagging -- BUT, when I went to try Pokemon White, suddenly it wouldn't work! It got stuck on the 'loading..' screen as well. Someone had recommended on yahoo answers (for someone else with a similar problem) to just delete everything on the cart, redownload the firmware, then read the games. Didn't work for me. Then I thought if I tried a bunch of kernals and firmwares from different developers I might be able to fix the problem.. but that was until I learned I had to use software specifically supplied by my cart's website (also, through trial-and-error, the cart wouldn't load at all with other firmwares).
    SO I went back to R4-Download - R4,R4i-R4isdhc the beta r4 card and went to the link corresponding to my update version (3.0.0.6, second one down), which says it works with the 3.0 update.. but there's no link under the firmware update header!! To top it off, there's no e-mail supplied to contact the developer so I had to assume that the previous version's firmware (third one down on R4-Download - R4,R4i-R4isdhc the beta r4 card ) was fine and all I had to do was update the kernal. So, I tried that and NOW all I get is a white screen when I try to access the r4i card. After a little research I found R4i-SDHC 3DS v3.0 Upgrade White screen error fix (due to v1.49b) | 3dscardshop.co.uk Blog thought/think this might be the issue -- BUUUUUT, only problem with that solution is that, before I even updated my 3DS to 3.0.0.6, I got the same problem: white screen when trying to access the card when the above solution says it's for users who upgraded to 3.0.
    So now I'm back to square 1. I don't know if this is a problem where my cart is being blocked because I updated my 3DS or something else. I've done SO many combinations of attempt-solutions I can't even record them all here accurately.
    Oh, lastly -- is my Pokemon White game screwed up for good?? I don't know if when a game doesn't load, it's gone for good or it's the actual console's problem, not the game, or what. Sounds so nerdy of me haha but I wasted so much time on that game, it'd be beyond frustrating to know that all of those hours have gone down the toilet.. At first I thought it was just a matter of weeding out a 'bad' game, but after taking all of them out and plugging in just my pokemon game (which was working perfectly for months) and still not getting anything, I'm just .. x_____x If anyone could help me out with that as well I'd really appreciate it!
    If anyone could help me out or enlighten me just a little -- please, please, PLEASE -- I'd so appreciate it!!! I'm driving myself nuts here!!!
    Thank you!
  • barrowmanandrew
    • 3427
    ok then..
    1. the console:
    what version firmware is your console running?
    (to check , switch on console without a gamecatridge in, then press system settings(spanner icon) and your vresion will be displayed on right hand side of top screen).
    i doubt you have updated with yer console unless you have dona an online updtae.
    2. flashcard:
    what flashcard is it?
    can u post a picture of it or a link to a card that is exactly the same.
    3. sd card:
    have you tried formatting and starting over?
    formatting sd cards using the panasonic formatting tool solves alot of problems.
    Digital Kaos - Downloads - sd formatting tool
    4.firmware:
    do you have a link to the firmware you were using when the pokemon game worked?
    5. games:
    are any games working now or nothing at all?
    • flyin
      • Feb 2011
      • 205
      Tell us you reformatted the sd card with a decent sd formatter nearly always solves these issues
      • superasian
        • Jan 2012
        • 9
        Originally posted by barrowmanandrew
        ok then..
        1. the console:
        2. flashcard:
        3. sd card:
        4.firmware:
        5. games:
        1. yup i did an online update -- it's Ver. 3.0.0-6U
        2. sorry messed up -- the url is R4 cards - Nintendo ds r4 - R4i sdhc Official website
        3. thought this might actually solve the problem -- i had thought i formatted the card using a different formatter -- but it still doesn't work after using the panasonic formatter.. in fact, after reformatting the card and then updating the firmware or whatever through the file provided by r4isdhc.com, my ds gets the ''error, press and hold the power button.." etc. screen instead of the ''loading..'' screen X|
        4. unfortunately i didn't note exactly what i was pasting over because i thought it was just gonna be a 1,2 kinda thing, but i do remember the dashboard looked a lot different.. i'm sure it was Wood firmware because it was in my directory and the skin was Wood. but when i tried downloading it onto my card, it wouldn't load at all :/
        5. none of the games are working
        as i said above, the reformatting didn't work :/ unless i'm reformatting and redownloading the files incorrectly.. it's confusing because r4isdhc.com gives so many different files, some of which overlap, so i don't know if i'm downloading them in the right combination of what x___x
        • barrowmanandrew
          • 3427
          well, think you'll be needing a new card then.
          according to the cards website,
          your card can only be used on 3ds v2.1.03 and below.
          even fully updated that card cant play on a3ds v3..
          if you look down their list of cards, it tells you which ones will work on latest 3ds...
          • superasian
            • Jan 2012
            • 9
            [ATTACH]96311[/ATTACH][ATTACH]96312[/ATTACH]
            [ATTACH]96314[/ATTACH]
            oh jesus haha well $20 for 4 months, not bad i guess.. thanks for your help! i thought i'd need a new card regardless so i'd ordered R4i 3DS card available at R4iShopper.com . it was recommended by this forum and it says it's compatible with 3.0.0-5E -- will it work with 3.0.0-6 you think?
            i just have one last problem: i also have the original nintendo DS and when i run the card on it, since the firmware is much lower than the 3ds, the dashboard DOES show up, but the games still won't load -- it gets stuck on the ''loading..'' page.. any suggestions?
            • barrowmanandrew
              • 3427
              it will only work if you upgrade it..
              personally i would go for an acekard.
              your current card should work on your dslite.
              reformat the sd card and reload the firmware/games from scratch...
              see how you get on..
              • superasian
                • Jan 2012
                • 9
                bah, sorry, new to this .. can i upgrade the card once i get it? or do i have to return this one and order a new one ugh -___- if that's the case, do you have any recommended sites for an acekard?
                thanks again! i'll try RE-reformatting and reuploading everything else.. is there anyway i can still salvage my saved pokemon white game though? :c
                • flyin
                  • Feb 2011
                  • 205
                  [QUOTE=superasian;1397281]bah, sorry, new to this .. can i upgrade the card once i get it? or do i have to return this one and order a new one ugh -___- if that's the case, do you have any recommended sites for an acekard?
                  What formatting tool you using there my good friend
                  • superasian
                    • Jan 2012
                    • 9
                    [quote=flyin;1397298]
                    it says it works for mac but i couldn't seem to download it so i just loaded it onto my windows partition via virtualbox.
                    • superasian
                      • Jan 2012
                      • 9
                      sorry guys to be asking another question.. the new card i ordered hasn't come and apparently r4ishopper (the website i ordered it off of) is closing for business..?? i e-mailed them about 4 days ago and they never answered me back and when they did a few days before THAT they didn't even answer my question in full! i was just wondering if you guys knew: they provide an update for their cards to break the 3.0.0-5 update, but does that mean it will work for the 3.0.0-6 update? i'm PRAYING it will because when i see other people post about cards breaking the update, they regard it as the "3.0" update without specifying "5" or "6" but yeah any help/advice would be appreciated as always thanks!
                      • gamer
                        • Jul 2013
                        Ive checked and it seems the site is back online, though it does look different then when I bought from them. You may wanna think about contacting them via email to make sure you either get the item, or you get your money back.
                        • gamer
                          • Jul 2013
                          oooopss!! Well, that's not a good helpful first post I just noticed the date on the OP's question. Sorry! This thread is old, and I replied as if it were new!
