hi i have a nintendo ds charge problem . when i plug it in to charge it the orange light comes on for a second or so then goes out . i have tryed another battery and charger but no luck . any ideas any 1??
cheers lee
yes mate theres a fuse on the board thats gone if you look on youtie theres a video on how to fix this with a steady hand and a small soldering iron and solder i did mine and it worked no hassle
he uses a pen which is quiet expensive try one fuse at a time as one might only be gone save ya doing to for no reason as one is in a tight spot [ame="http://www.youtube.com/watch?v=502qoZO4hTE"]How to Fix a Nintendo Ds Lite that won***39;t power on or charge . - YouTube[/ame]
forgot to metion if the second battery was fully charged and still not working then you will most likely need to do the two fuses
