Help with DSTT card please
  • debbie1608
    • Mar 2009
    • 21
    Sorry have looked through the threads and not sure if my problem is the same as others have posted
    Had the DSTT card since Christmas and all has been working fine apart from having to reformat it a couple of times, but now when you put the card in you just get a very feint screen which won't actually respond to anything. Now and again it loads properly but only about 1 in 20 times, have checked the micro sd card with another dstt card we have and that still works fine.
    Not sure if it's got anything to do with it but i upgraded the firmware (from dstt site) on saturday and the problems started shortly afterwards, i have tried removing the new firmware and replacing it with the old firmware but unfortunately it hasn't solved the problem.
    Also tried the piece of card behind the dstt cart, that didn't work either.
    Any help would be appreciated, thanks.
    Last edited by debbie1608; 16 March, 2009, 11:27. Reason: forgot the pice of card trick
  • dell_xps
    • 2558
    Welcome TO DSTT Official Website
    Def an original TT card ?
    • debbie1608
      • Mar 2009
      • 21
      yep checked via the dstt site and it's not a fake.
      • dell_xps
        • 2558
        Fomat your memory stick in your computer, use the very first firmware you had working, try one game at a time, might just be a corrupt game causing the trouble.
        • debbie1608
          • Mar 2009
          • 21
          Nope fraid it didn't work, still doing the same
          • dell_xps
            • 2558
            Format again, put the latest software on it, try another game, if that doesnt work I'd say the TT card is probably the fault.
            • MetalKettle
              V.I.P.P.T. Member
              • 797
              Try holding the card and twisting it slightly. I had a problem similar to this and this seemed to solve it. It might be just a case of the contacts on the card not making contact with the pins in the DS.
              XBMC/KODI Developer
