dstwo card not working
  • NICETOBNICE
    • Nov 2011
    • 551
    hi chaps my sons card is suddenly not working i suspect the firmware has been updated but not sure what to do
    any ideas guys
  • barrowmanandrew
    • 3427
    which console do you have?
    and what firmware is it on?
    here is the latest update file for that card.
    SuperCard Fireware 1.18.rar
    unzip and put file on sd card along with your firmware, then put card in an older console that it works in, and run the update....
    • NICETOBNICE
      • Nov 2011
      • 551
      [ATTACH]151060[/ATTACH]
      Thankyou
      i have just formated my sdcard so have nothing on there at the moment it had errors and thought it best to start again could you tell me what else i need i really cant remember
      • barrowmanandrew
        • 3427
        also need the firmware.
        that should be it..
        • NICETOBNICE
          • Nov 2011
          • 551
          done that inserted in the 3ds and same error when pressing alex stormrider also tried it in the dslite and showed nothing at all ?
          • barrowmanandrew
            • 3427
            should work in the dslite. ?
            what firmware is the 3ds on?
            • NICETOBNICE
              • Nov 2011
              • 551
              Thats guys its all done
              great stuff
              now i have another problem
              I have downloaded loads of games to put on the micro sd card which is 32gb.
              when i select all the games to copy on to the card even 10 at a time' some do not display on the 3ds but if i copy them 1 by 1 they work there's 100s of games in all am i doing something wrong ?
              • barrowmanandrew
                • 3427
                should be able to copy them all at once, must not be transferring properly.
                did you use the panasonic formatting tool to format the sd card?
                • NICETOBNICE
                  • Nov 2011
                  • 551
                  thanks guys all sorted now i have swapped sd card and seems to working great thanks guys
