3ds ver.4.1.0-6u for acekard 2 pls help?
  • janno03
    • Dec 2012
    • 10
    3ds ver.4.1.0-6u for acekard 2..it say un error accured..pls help
  • barrowmanandrew
    • 3427
    update the acekard
    • janno03
      • Dec 2012
      • 10
      i already update it.i even format the sd card but no luck.
      • janno03
        • Dec 2012
        • 10
        my daugther update her 3ds cause she have new game and it say u can only play this game if u update it then she update it.and then it started to have a message like that u error occured when i insert my acekard..pls help
        • barrowmanandrew
          • 3427
          what icon does the card show up as?
          • janno03
            • Dec 2012
            • 10
            prince icon
            • barrowmanandrew
              • 3427
              prince caspian?
              you need to update the card firmware.
              this can only be done on a console that the card currently works in..
              1:extract the file you need with AKAIO firmware to sd card
              2: put acekard in console it surrently works in
              3: browse to update file (just like loading a rom) and follow instructions.
              when done the icon should change to a horse with a green background, pippa summit or another..
              • janno03
                • Dec 2012
                • 10
                i did everything you tell me and load the acekard with the icon prince of caspian then after that an error has occurred.
                • janno03
                  • Dec 2012
                  • 10
                  do my acekard blocked? can this one still be fix? pls help
                  • barrowmanandrew
                    • 3427
                    your current consoile will be block the flashcard, but the card can be updated.
                    this is not to be confused with the AKAIO firmware (which is the loader) found on the sd card.
                    the update file will flash the card so it can work on newer conmsoles.
                    the latest update will allow the acekard to work on dsi up to 1.4.4 and 3ds up to 4.3.
                    the update file is a .nds file ,there is 2files, one for updating on dslite and one for dsi/3ds.
                    the bad news is that you cant use your current console to update, you will need a dslite or older 3ds/dsi.
                    have a read through this, it will give you an idea...
                    Digital Kaos - Downloads - acekard update for 3ds v3.0 and dsi v1.4.3
                    but use the update file i linked earlier.
                    • janno03
                      • Dec 2012
                      • 10
                      thanks i find someone who has a 3ds or dsi to update it..thanks
                      • barrowmanandrew
                        • 3427
                        try and find a dslite..
                        • janno03
                          • Dec 2012
                          • 10
                          hi can i update it on a ds lite? and it doest matter what firmware version ds lite has?thanks
                          • barrowmanandrew
                            • 3427
                            updating on a dslite is the preferred method as it doesn't matter what version firmware the dslite is on..
                            • janno03
                              • Dec 2012
                              • 10
                              thanks again..
