DSTT Card Help
  • stuwho
    • 20
    DSTT Card Help
    I was told that the DSTT card can play media & music. I copied the menu files from my other card & put a movie on it but it doesn't play. It doesn't even appear on the list. All that comes up is SysOption in the top left corner, then a column for Icon, name & size which are all empty. If I click on SysOption all I get is Default reset off/on, PASSME Mode, GBA Mode Power Off & brightness. Does the media have to be a certain format, I have tried MP4 & avi but none work. Any help out there?
  • Bravo111
    • 69
    I put moonshell software on abd it works fine with movies.
    • MetalKettle
      V.I.P.P.T. Member
      • 797
      You will need some other software to run movies and play music.
      As Bravo111 mentioned, Moonshell is good for this and the player supports DPG video files, MP3 / OGG / MOD / SPC / MDX (no PCM) / GBS / HES / NSF / XM / MIDI / WMA / low bit rate AAC audio / non-progressive JPEG / BMP / GIF / PNG images, and text files.
      XBMC/KODI Developer
