DSI Error
  • Natasha22
    • Mar 2010
    • 9
    DSI Error
    I'm new to this site. My son has a dsi and when he loads it says an error has occured and to turn off the power, any advice would be much appreciated.
  • opsmonkey
    • 5379
    it sounds like you have recently updated the DSi.. This would explain why the card no longer works.. you need to update the firmware for the DSi card you have bought
    • Natasha22
      • Mar 2010
      • 9
      Hi
      As far as I know nothing has been updated. The problem is is that none of his original games work either. We also get the same error message when trying to go into system settings. The only thing that works is the camera.
      • opsmonkey
        • 5379
        from what i can see and know the error you describe is down to only a couple of things.. namely that the DSi has updated and now blocks all pirated games and carts like the R4i
        If original games wont work then i suggest you take it back to where you bought it from and get it replaced under warranty
        Are the original games definitely 'original'..??
        If you got the games off ebay there is a real chance that they are pirated..
        • Natasha22
          • Mar 2010
          • 9
          All of the games are original from places like Asda, Game, HMV etc.
          • opsmonkey
            • 5379
            Take it back to the shop you bought it from show them the problem and get it replaced under the warranty..
            The error you are seeing is normally from using a pirated or fake card..
            However this time it may be an internal operating error with the machine..
            i.e. its knackered
            • Natasha22
              • Mar 2010
              • 9
              Thanks for the help, I'll take it back. Can the shop tell that I've been using a r4i card?
              • opsmonkey
                • 5379
                No... they cant and even if they ask if you have, play dumb..
                Ideally take your original games with you to show them
                • jinxy72
                  • 38
                  what happens if u start it up without a card in it ? can u get into the settings then ?
                  • Natasha22
                    • Mar 2010
                    • 9
                    No, even when there's nothing in the DSI it still has the black error screen
