DSI Gold
  • nuttygoody
    • Nov 2010
    • 4
    DSI Gold
    I got a new R4i Gold card. I uploaded the kernel and while trying to run a game I get this error on moonshell.
    BootROM.cpp:196 BootROM_Execute: #10005: Not support commercial NDSROM file.
    This is the error file that shows in logbuf.txt
    Start log file. topsector=63560 size=4096byte
    AppName MoonShell Ver 2.02 stable
    Jun 11 2009 15:23:51 GMT+09:00
    ARM RVCT3.1 [Build 794]
    __current pc=0x02001398 sp=0x02803ea8
    DLDI: active_interface= 0x020994e0, ID= R4i , Name= R4i DS .
    active_interface->ul_Features= 0x23.
    Boot with DSi.
    Shell_FAT_fopen_Data=/MOONSHL2/VERSION.DAT
    Shell_FAT_fopen_Data=/MOONSHL2/MOONSHL2.DAT
    FAT2: Disabled 64k cluster mode. Start fast mode.
    pDTCMEND=0x02800ddc, pMTCMEND=0x028028c0. MTCM size=6884byte.
    Start FPGA Initializer.
    Can not found ROMEO2 cartridge on GBA slot.
    mainloop.
    Boot from NDS card.
    DSBM:0, EZ3in1:0, M3ExtPack:0, RawMem:0, SuperCard:0, maxsize=0.
    extmem_Init: Not found extend memory cartridge.
    extmem: Extention memory was not found.
    Setup default code page is '000'.
    Loaded font for your language.
    pTextPool used.16kbyte remain.2703kbyte
    Succeeded memory optimization.
    Language materials count= 385
    CreateBurstList.
    Get RTC data from ARM7.
    4,4,4,4,Initialize random seed.
    ResumeDataSectorIndex=67120.
    Check current path. [/games]
    finded. [/GAMES/]
    Set NextProc.
    Found ExtLink file. (0) [IPK.NDS]
    Found ExtLink file. (1) [NESNES~1.NDS]
    Not found alias skin file '/MOONSHL2/def_000.skn'.
    Skin file size: 399136byte.
    DStack:0 Pos:64, Used:4996, Total:12580.
    Start event loop...
    Disk read-write check. [/_CHKDSK_.$$$] / Open file for write. / File write. / Check position. / File seek. / Check position. / File close. / Open file for read. / File read. / Check position. / Check values. / File close. / Remove file. / Succeeded.
    Start read 16bit test.
    DStack:1000 Pos:88, Used:3524, Total:12580.
    strpcm stopped.
    strpcm stopped.
    DStack:1001 Pos:64, Used:284, Total:12580.
    Wait for key releases. (NextProc=11)
    Splash_Free: Free.
    Load launch data '/MOONSHL2/LAUNCH.DAT'
    launch data load from '/MOONSHL2/LAUNCH.DAT'.
    Add launch file. [CHECKD~1.NDS]
    Add launch file. [IMAGEV~1.NDS]
    Add launch file. [MORNIN~1.NDS]
    Load icons.
    Current folder refreshed.
    DStack:1000 Pos:88, Used:3452, Total:12580.
    Launch edit: Delete equal item 0.
    Launch edit: FilesCount set to 0.
    Launch edit: Add to top.
    Launch edit: FilesCount set to 1.
    Launch edit: New item set to 0.
    Launch edit: end.
    Save launch data '/MOONSHL2/LAUNCH.DAT'
    Saved launch data. 5148byte.
    DataFullPathFilenameAlias=
    NDSFullPathFilenameAlias=/GAMES/WRG-BBA.NDS
    strpcm stopped.
    strpcm stopped.
    Close launch data.
    DStack:1001 Pos:64, Used:2932, Total:12580.
    DStack:1000 Pos:88, Used:96, Total:12580.
    Detected ROMID: AYAE
    Application halted !!
    Please refer [/moonshl2/logbuf.txt]
    How to solve this?
  • barrowmanandrew
    • 3427
    you dont open moonshell to start games.
    moonshell is for playing .dpg movies and mp3's.
    just browse directly to the game
    • nuttygoody
      • Nov 2010
      • 4
      Sorry. New to this. How do I start the game. I tried one by selecting the game and pressing A. It said Loading and nothing happens after that.
      • barrowmanandrew
        • 3427
        more detail is needed.
        what type of ds are you using ds/dsi (if dsi which version firmware is it running)
        which games you having probs with (all games or certain games)
        which card do you have (please be as accurite as you can, post a screen shot if poss)
        where did you get your firmware for card? provide link please
        • nuttygoody
          • Nov 2010
          • 4
          dsi version 1.4 u
          Problem game is Big Brain academy at Big Brain Academy - NDS9.com Free NDS GAMES
          Card is R4i Revolution for DS ( Gold) - picture attached herewith.
          Got firmware from R4i,,R4i Revolution For -R4i.
          • opsmonkey
            • 5379
            this looks like a fake card to me.. the 3 golds i have are made by this company and are a yellow / gold colour
            R4i-GOLD Revolution for NDSi/NDSL/NDS
            • nuttygoody
              • Nov 2010
              • 4
              Is there a kernel or program for this card then?
              • barrowmanandrew
                • 3427
                do most games work?
                does it appear to be newer games that don't.
