nintendop DS XL
  • celast
    • Dec 2010
    • 45
    nintendop DS XL
    I am getting a Nintendo DS XL,I believe you can access the web with it, does my pc have to be wireless or will it pick up the signals once password etc is put in ?
  • mickydibble
    • 2166
    Your pc doesn't have to be wireless ,but you need a wireless router
    • celast
      • Dec 2010
      • 45
      I have a HUAWEI wireless modem, will that do ? Thanks
      • mickydibble
        • 2166
        If it allows wireless connections yes,you would have to set it up on ds and should be just password etc,see if your wireless box is found by the ds
        • celast
          • Dec 2010
          • 45
          Thanks, I will give it a go when I get it.
          • celast
            • Dec 2010
            • 45
            I would like to connect the DS to the internet but, the PC is upstairs and I want to view the DS downstairs in the lounge
            is that possible ? I did try but it could not connect, do I need a wi-fi USB adaptor or should I be able to connect without this ?
            the Pc at the moment has a brand new wireless router but is wired to the PC, any help would be appreciated
            • mickydibble
              • 2166
              Try connect near to wireless router, then go wherever n see if you get connection still in different rooms, if it's a wireless G should have no probs ....
              • celast
                • Dec 2010
                • 45
                Can't get it to connect right next to the PC, what are ssid settings? thanks.
                • dell_xps
                  • 2558
                  ssid is the name your router broadcasts so you know what to connect to.
                  Then you will have to enter the encryption keys, if you have set one, if not it should connect automatically.(best to have encryption enabled on your router).
                  • barrowmanandrew
                    • 3427
                    your wireless router will probably be protected.
                    this is how to set up the connection on a protected or locked wireless router.....
                    1. go into "system settings", "internet"," connection settings".
                    2. tap "advanced set-up".
                    3. select a connection (either 4,5 or 6.)
                    4. tap "search for an access point"
                    a list of available wireless networks will appear.
                    5. tap which ever network is yours.
                    you will now be presented with a screen giving some info about your wireless network.
                    if your network is protected it will say "this access point is secure"
                    6. tap the grey box in the middle of the screen.
                    you will now be presented with a keyboard.
                    7. tap in your network password and hit "ok"
                    if you have done it right the dsi will attempt to connect to your router, if successfull it will test the connection and save the settings.
                    you may be prompted to agree to their terms and conditions.
                    after that go into the main menu and start the browser.....
                    • mickydibble
                      • 2166
                      Have you connected wirelessly before to box ?if not check website for default settings for box(wireless)/You either got a password or not,or if you cannot find it through ds .then maybe need to reset router ,pin size button, on box .and then goto web,routerlogin.net...and set your network.
                      • celast
                        • Dec 2010
                        • 45
                        How do I find out what the SSID is ? also how do I enable encryption on the router?
                        • celast
                          • Dec 2010
                          • 45
                          Found the SSID, but what do I do for the encryption ?
                          • cunny
                            • 4915
                            WEP as the ds only supports WEP
                            • barrowmanandrew
                              • 3427
                              your router should be already set up.
                              how do you connect lappy's etc to it?
                              or are you not using the wireless function on it?
