Nintendo problem
  • plamen.1973
    • Sep 2009
    • 125
    Nintendo problem
    hello,guys
    I make problem on my Nintendo ds xl when I updated first.
    Now I can't use my Acekard 2i to play the games.
    Black screen and blue font"System file missing".
    I download everything to updated the Acekard 2i:
    akaao 1.8.1; ak2loaders;ak2ifm update;ak2menu .
    And still have the same problem.
    Please help? thank you
  • barrowmanandrew
    • 3427
    hi m8,
    try following the advice from this thread,
    post back results..
    • plamen.1973
      • Sep 2009
      • 125
      Originally posted by barrowmanandrew
      hi m8,
      post back results..
      I did same routine but didn't solve the problem.
      • barrowmanandrew
        • 3427
        ok m8,
        do you have or can you get a dslite you can use for ten minutes?
        it will be easier to identify problem if you have a dslite and a dsi
        • plamen.1973
          • Sep 2009
          • 125
          ok m8,
          I can't borrow DS lite I don't know my frieds have it.they haven't got it.
          any other way to sort my problem,please?
          Can I restore to previos verson my Nintendo?Is it possible?
          Thank you.
          • barrowmanandrew
            • 3427
            if you have updated your dsi to 1.4.1 then your card may need updated too.
            you can only update card on an older dsi or a dslite.
            we need to work out whether your card needs updated or if the sd card is set up properly.
            it would be easier to do if you had a dslite...
            the only thing i can suggest is following this short guide carefuly again,
            remember to format the sd card first.
            1. backup/reformat your sd card..
            2. download latest firmware
            Digital Kaos - Downloads - akiou 1.8.1
            3. extract the files and copy the "_aio " folder and "akmenu4.nds" file to the root of your sd card, do not put in a folder....
            4. add games to taste and enjoy...
            if you are still getting the same message, then the acecard is either a clone or needs updating.
            you will need an older console before we can go any further.
            • plamen.1973
              • Sep 2009
              • 125
              i think to buy DS lite from Argos then return it back to them.Will DS Lite work with Acekard?
              • barrowmanandrew
                • 3427
                , your are taking a risk ther..
                can u check which version firmware your dsi is running?
                • plamen.1973
                  • Sep 2009
                  • 125
                  Version 1.4.1E
                  • barrowmanandrew
                    • 3427
                    yes acecard works with dslite,
                    you need a dslite or older dsi to check/update acecard.......
                    if you really cant get an older console, then post your card to me recorded delivery.
                    i'll have a look and post it back to you.....
                    • plamen.1973
                      • Sep 2009
                      • 125
                      Thank you very much.
                      Which is your address?
                      • barrowmanandrew
                        • 3427
                        i've sent you a p.m. m8
