darkcorpv1.1
  • ck-ok
    • 2592
    darkcorpv1.1
    here is darkcorpv1.1 full [HMN] DARKCORP v1.1 Full.rar
    darkcorp allows owners of older wii's to play backups directly from the normal game channel.
    What is it?
    It's a complete software modification for your Nintendo Wii to
    allow you to play almost all of your in-region backup burnt Wii
    and GameCube games via the disc channel without opening your
    console or having to use a loader application.
    What is needed (other than this package):
    - A Nintendo Wii (to modify)
    - An SD card with approx 100MB of free space
    - Ability to run Wii homebrew (preferably Homebrew Channel installed,
    or via indiana pwns savegame hack (via another loader though. loadMii
    prevents the Wiimotes from syncing when installer is loaded.)
    Optional, but recommended:
    - bootmii (preferably as boot2):
    We highly recommend installing bootmii, and making a NAND backup,
    and/or installing preloader prior to installing DARKCORP v1.0.
    - preloader:
    Also, installing preloader with a hacks.ini for your System Menu is
    recommended, as it has some useful hacks, such as region free games.
    - cIOS249:
    To run the installer. If you don't have these, the installer can
    install cIOS249 rev17 for you.
    How risky is it to install?
    DARKCORP v1.1 overwrites the majority of the system files (IOS)
    on your Nintendo Wii with modified ones which "know" how to handle
    DVD?R discs, so the installation process itself is about as risky as
    an official Wii System Update (but less dangerous than the 4.2/4.3 Update).
    You should be fine if you just let the installer run though.
    How to install it:
    Unpack the contents of this .zip file to your SD card and run the
    "DARKCORP v1.1 Installer" application application via the Homebrew Channel,
    or load up another loader via indiana pwns, and use that loader to load it,
    then select the installation option that suits you.
    If you already have cIOS249 installed, select:
    Install/Upgrade to DARKCORP v1.1 (regular mode)
    If however, you don't have a usable cIOS249, select:
    Install: Virgin Wii method (TBR + cIOS249 r17b + CORP)
    This will install cIOS249 rev17 (with DL bug fix), then use it to
    install DARKCORP v1.1. Only use this method if you need it! If your Wii
    does not need this method, it will give an error, such as error -1035.
  • scudbuster
    • Mar 2012
    Gratitude
    Many thanks for the downloads!!
    • happy_highlander
      • 3535
      Ck are you mad ......that ~~~~ers a brick waiting to happen if you don't know how to deal with it.
      • ck-ok
        • 2592
        ! yeah had a bit of a crazy moment one day.
        but that said it can be a great program if they have young kids and are using dvd backups cause they can boot them straight from the normal game channel but that you already know.
        best not mention pimpmywii then?
        • happy_highlander
          • 3535
          I agree mate it is fantastic at what it does but christ it's dangerous if you haven't installed bootmii as boot 2. At least it's easier to get rid of now though as a complete softmod with modmii uses the all the proper file versions for a safe uninstall
