neogamma 7 timeout
  • skegsagypsy
    • Aug 2009
    • 1230
    neogamma 7 timeout
    Constantly getting timeout on my wii 3.2e softmodded using neogamma 7 IOS249 REV 14, Anyone offer help or advise please, pulling my hair out here.
    'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
    -Bishop Desmond Tutu
  • ck-ok
    • 2592
    try a newer neogamma http://www.digital-kaos.co.uk/forums...-9-r26-144993/ and a newer cios249 Digital Kaos - Downloads - ciosx r19 full
    • skegsagypsy
      • Aug 2009
      • 1230
      Thanks for the help ck, no joy though
      • ck-ok
        • 2592
        what happens exactly?
        • skegsagypsy
          • Aug 2009
          • 1230
          Put disc in load neogamma, and I get a timeout error.
          • ck-ok
            • 2592
            is this just on one backup or all?
            if its just the one then i would say its a bad burn,only use quality dvd-rs burnt with imgburn slow speed.
            also try a cd lens cleaner to make sure theres no dirt that might be causing this error.
            • skegsagypsy
              • Aug 2009
              • 1230
              All backups and original discs ck, nothing works!
              • ck-ok
                • 2592
                try running neogamma from homebrew channel rather than from main menu.
                if you still have no joy try playing your backups with uloader http://www.digital-kaos.co.uk/forums...taller-143444/
                • skegsagypsy
                  • Aug 2009
                  • 1230
                  I have a feeling the laser may be the problem, is it worth changing it ?
                  • ck-ok
                    • 2592
                    have you tried a cd lens cleaner yet?
                    • skegsagypsy
                      • Aug 2009
                      • 1230
                      Yes m8, it wouldn't run either
                      • ck-ok
                        • 2592
                        could well be your drive then, can you get get your hands on a usb pen and see if backups run off that before going any further?
