Wii Softmod Tutorial for noobs like me
  • slimjim
    • 23
    #301
    Bannerbomb used
    Used the boot.dol from this pack
    on bannerbomb worked like a charm finished tutorial
    thankyou again ............thought i had messed up LOL
    just gotta test it all now .....
    • Yumraaj
      • 306
      #302
      Glad you got it working again mate.
      • slimjim
        • 23
        #303
        JOB DONE !!! EXCELLENT !!!
        WORKING 100 % thanks again m8
        Now all working again is it safe to use the network to update hbc or shall i just leave as is
        any ideas
        • Yumraaj
          • 306
          #304
          any ideas
          If it is working I would leave it. To be on the safe side install preloader and forget about it, this will your life saver if anything goes wrong with you wii. It happen to me that is why I am telling you this.
          • slimjim
            • 23
            #305
            Preloader ??
            Could you give me some more info on this please
            currently my wii is set as of the tut and 3.2e
            only chose skip disk update in starfall or should i choose more
            please recomend thanks again
            • Yumraaj
              • 306
              #306
              Starfall is good but preloader is more for emergency purposes. If for any reason you are trying to install something on you wii and it mess it up, preloader will be able to get you in HBC and do what ever you want from there. But before you install preloader make sure you remove starfall from your wii.
              • slimjim
                • 23
                #307
                preloader
                Thanks m8
                will look around for it ......unless you got a safe link there for me thanks again
                • Yumraaj
                  • 306
                  #308
                  Thanks m8
                  What system menu are you using mate 3.1, 3.2, 3.3, 3.4 or 4.0 and what version PAL, NTSC OR NTSC-J?
                  Please let me know.
                  Have a look at this and see if you can make any sense:
                  • slimjim
                    • 23
                    #309
                    preloader
                    System menu is 3.2e PAL
                    thanks for link will check it out .
                    • Yumraaj
                      • 306
                      #310
                      Ok mate this is what you got to do. Download it from this link:
                      For more indepth tutorial read tutorial inside folder
                      1. Extract it to your PC, make a folder call preloader in apps folder on your sd card.
                      2. Rename preloaderv0.29-cred.dol to boot.dol (if not already renamed) and put it the folder you just created.
                      3. Put the hack.ini file in the root of your SD card. Go to HBC and launch preloader.
                      4. OK now select Pre Loader from the HomeBrew Channel.
                      ****** Read the warning and press 1 to install.*****
                      IF YOUR SYSTEM DOESNT REBOOT INTO PRELOADER, SIMPLY POWER DOWN AND POWER UP ONCE MORE, BUT AS SOON AS YOU POWER UP, PRESS AND HOLD RESET
                      5. Select “System hacks” ->
                      6. Enable all the hacks you would like, (recommended - Skip Updates, Move Disc Channel)
                      7. Select "save settings" and wait for confirmation message to display “Settings Saved”
                      8. Press B, and enter Settings
                      9. Set "auto boot: System" (using the D-Pad Arrows), and save settings with A, then Press B
                      10. Get back to the system menu. By selecting “Load System Menu”
                      11. If you want to get into preloader menu in the future, just switch wii on and press reset button.
                      That is it, you have just protected your wii and if anything happen to your wii in the future, at least you know it is protected.
                      N.B: If you already have starfall installed please remove it first then install preloader. Starfall is good but it only works with 3.2 version whereas preloader works with all and goes beyond starfall alltogether.
                      • slimjim
                        • 23
                        #311
                        preloader
                        Thanks will follow this and let you know how i get on m8
                        cheers ..........been away for a while ....
                        can i use internet for all games or is bet to stay off line
                        dont know much about this stuff sorry but learning all the time now by coming here and doing some research thanks again
                        for all the help ........... so far LOL
                        • Yumraaj
                          • 306
                          #312
                          You can still go online mate.
                          • slimjim
                            • 23
                            #313
                            help please
                            yes the nag is back
                            i have had green screen how do i avoid this please
                            any help only had 1 game give me this...... sims racing
                            any suggestions much thanks in advance ..........
                            thanks for all previous info and help ......... helped me a great deal...............cheers
                            • Yumraaj
                              • 306
                              #314
                              yes the nag is back
                              Are you playing Sim racing burnt on dvd or usb? If it is USB try installing the latest rev, hopefully this will fix it.
                              Digital Kaos - Downloads - cIOS38_rev13-Installer with wad
                              • slimjim
                                • 23
                                #315
                                cheers m8
                                updated to Rev 13b
                                also used neogammaR5 chose launch dvd from menu
                                with 002 error fix on SORTED thanks
