Can not play any games
  • torakuma
    • Apr 2011
    • 15
    Just softmoded 4.2U with Mauifrog"s "Mod Any Wii" and installed the newest USB GX loader but still can't play any games. Games all show up on screen and I have downloaded all covers for them but when I hit play I get a black screen with the message "Error, please consult your Wii manual" Gammes are all on a WD USB Drive and play fine on a different modded Wii and the mod went smooth with all OK's. Copy of System Check below:
    sysCheck v2.1.0b7 by Double_A
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.0/4.1U (v54449)
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x11
    Console ID: 105198266
    Boot2 v4
    Found 76 titles.
    Found 48 IOS on this console. 2 of them are stub.
    IOS9 (rev 54321): Trucha Bug, NAND Access
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug, NAND Access
    IOS12 (rev 526): NAND Access
    IOS13 (rev 1032): NAND Access
    IOS14 (rev 1032): NAND Access
    IOS15 (rev 1032): NAND Access
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access
    IOS17 (rev 1032): NAND Access
    IOS20 (rev 54321): Trucha Bug, NAND Access
    IOS21 (rev 1039): NAND Access
    IOS22 (rev 1294): NAND Access
    IOS28 (rev 1807): NAND Access
    IOS30 (rev 54321): Trucha Bug, NAND Access
    IOS31 (rev 3608): NAND Access
    IOS33 (rev 3608): NAND Access
    IOS34 (rev 3608): NAND Access
    IOS35 (rev 3608): NAND Access
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): NAND Access
    IOS38 (rev 4124): NAND Access
    IOS41 (rev 3607): NAND Access
    IOS43 (rev 3607): NAND Access
    IOS45 (rev 3607): NAND Access
    IOS46 (rev 3607): NAND Access
    IOS48 (rev 4124): NAND Access
    IOS50 (rev 54321): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS53 (rev 5663): NAND Access
    IOS55 (rev 5663): NAND Access
    IOS56 (rev 5662): NAND Access
    IOS57 (rev 5919): NAND Access
    IOS58 (rev 6176): NAND Access, USB 2.0
    IOS60 (rev 54321): Trucha Bug, NAND Access
    IOS61 (rev 5662): NAND Access
    IOS70 (rev 54321): Trucha Bug, NAND Access
    IOS80 (rev 54321): Trucha Bug, NAND Access
    IOS90 (rev 54321): Trucha Bug, NAND Access
    IOS202[60] (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 65535): Trucha Bug, ES Identify, USB 2.0
    IOS223[38] (rev 65535): Trucha Bug, ES Identify, USB 2.0
    IOS224[57] (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS247 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS248 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS249[38] (rev 17): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS250 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
    Report generated on 2011/05/05.
  • ck-ok
    • 2592
    do any games work?
    what games are they?
    and you say you followed a tut for 4.2 but the check says 4.0-4.1
    • torakuma
      • Apr 2011
      • 15
      This Wii was Ver. 4.2U which I attempted to modify with the Fusion Modkey. Apparently the Modkey was defective as it shorted out the disk drive and resulted in me sending it out to have a stuck disk removed. The tech informed me of the defect and said I would need a new drive to make it functional again, he also removed the Modkey & the disk. I then decided to go the softmod route as I was already out $75.00 and did not want to spend another $100 for a new drive. In the meantime my wife picked up another Wii already modded and with a 1TB Usb drive loaded with games all of which seem to play. I copied all the games to a new USB drive,hooked it up to the new Wii and they played off of that drive also. After trying different Mod programs, all with failure, I then came across Mauifrog's "Mod Any Wii" Program which said Sucessfully Installed and thought I was good to go. I did not realize that it was also down grading me to 4.1. I then installed USB Loader GX Ver 2.0 and that's where I'm at now. No games will play although they all say loading........
      then then screen goes black and a few seconds later the read your Wii manual message appears and I have to re-boot.
      • C64
        • 2394
        Why not put in in the bin, or give it to a charity.
        • torakuma
          • Apr 2011
          • 15
          your reply did not seem too charitable, but thanks.
          • ck-ok
            • 2592
            what format is the drive?
            Remember: NTFS and FAT32 USB Loading will only work with Hermes cIOS222/223 v4+ or with cIOSx Rev19+
            try installing this Digital Kaos - Downloads - cIOS249[57]-v20 for COD black ops
            • Fellianis Wig
              • 427
              I'm not 100% on this but I'm sure I've read a wii with a totally dead dvd drive wont play copy games.
              • torakuma
                • Apr 2011
                • 15
                Installed Cios249(57)-V20 and same result. USB Drive formatted with WBFS. Thanks for your help everyone.
