tom clancys h.a.w.x 2
  • gaz1971uk
    • May 2011
    • 9
    running through coverfloader game runs but as soon as you go to start it freezes
    any ideas would be a great help
  • ck-ok
    • 2592
    update coverfloader or use gx or cfg loader
    • gaz1971uk
      • May 2011
      • 9
      can you update coverfloader over the consoles internet connection?
      • ck-ok
        • 2592
        depends on what version your on,try clicling on the cog in the bottom left of the main coverfloader screen if there is no auto update button then you will need to do it yourself from here wiicoverflow - CoverFloader - Google Project Hosting
        • gaz1971uk
          • May 2011
          • 9
          tried to update and kept coming up with error ret2011, so i tried updating the cios now coverfloader aint finding harddrive
          • ck-ok
            • 2592
            what cios did you update too?
            coverfloader is not the best usb loader if i was you i would delete it and install cfg or another loader Digital Kaos - Downloads - usb loaders
            • gaz1971uk
              • May 2011
              • 9
              cios249 ver20, i have that cfg and that aint finding harddrive, but it was working before i tried messing around trying to get hawx 2 to work, and that would load, let you select the profile, campaign , then freeze on loading
              • ck-ok
                • 2592
                what slot did you install rev 20 too? or did you use this Digital Kaos - Downloads - cIOS249[57]-v20 for COD black ops if not try installing the cios wad
                what system menu are you on?
                do you have cios 222/223?
                • gaz1971uk
                  • May 2011
                  • 9
                  wii menu ver 3.2, cios249[57], think i need to undo everything and start again
                  • gaz1971uk
                    • May 2011
                    • 9
                    right got harddrive working again with cfg but cant install it to channels using wad just getting ret 2011 error
                    • ck-ok
                      • 2592
                      try a newer wad manager Digital Kaos - Downloads - wad manager 1.7
                      what cios are you trying to install it with?
                      • gaz1971uk
                        • May 2011
                        • 9
                        cios249 rev20b wad manager 1.6,
                        • ck-ok
                          • 2592
                          try Home of Multi-Mod-Manager - A multipurpose all-in-1 tool for Wii too patch your ios36 as this sounds like your problem.then you should be able to install wads without any problems.
                          • gaz1971uk
                            • May 2011
                            • 9
                            that worked a treat thanks for the help on that, only thing i cant get it to do now is the cfg channel wont work just resets back to wii main menu, but it works fine through homebrew
                            • ck-ok
                              • 2592
                              sounds like you need ios58 installing read here BootMii.org
