usboader gx
  • ck-ok
    • 2592
    #16
    Originally posted by Keithuk
    Yes I have IOS36-64-3608 but how does that install IOS236 there is no ISO236 listed in NUS?
    I've search on here for IOS236 and a link that ajpepe72 has shown but the download link isn't available because Server is under technical emergency maintenance.
    Ios236 - GAF***039;s Wii Homebrew Tutorial
    You said
    I've search for cfg loader in that thread but nothing shows?
    Isn't IOS236 for the Configurable USB Loader? I wouldn't mind any bleeding loader Wiiflow or anything?
    no 236 is not for cfg loader read here http://sites.google.com/site/complet...g-guide/trucha
    or if you prefer a different loader try here Digital Kaos - Downloads - usb loaders
    • browno
      • 176
      #17
      hi,
      How do i run system check , have tried everything to get working ....please help
      • browno
        • 176
        #18
        is it worth re-doing everything again???
        will it work??
        • ck-ok
          • 2592
          #19
          will it work??
          have you tried what i said in post 14? you need ios58 installed if you want to run a fat32 drive IOS58 Installer - WiiBrew
          • browno
            • 176
            #20
            yes have tried that mate
            • ck-ok
              • 2592
              #21
              ok then try this ModMii for Windows - GBAtemp.net it will download all the files to run a hdd and write you a tutorial.
              • Keithuk
                • 2264
                #22
                Well this softmoding is pissing me off. USB Loader GX says it needs cIOS222, 249 or 250. Configurable USB Loader needs cIOS249. I couldn't remember where I had CIOS-PACK-v3.zip from so I Googled it CIOS-PACK-v3.zip which has cIOS222[38]-v65535.wad, cIOS249[38]-v21d2x4.wad, USBLoaderCFG - UCXF - IOS58 v9.wad with 9 other wads which I didn't try. I installed them with Multi-Mod Manager 13.4 but they wouldn't install.
                I've just downloaded ModMii for Windows - GBAtemp.net and ran it. I selected the options I wanted to install and it made them in COPY_TO_SD folder along with the wad folder. I set it to installed all 16 wads with Multi-Mod Manager but one wouldn't install USBLoader(s)-ahbprot58-SD-USB-v9-IDCL.wad.
                I ran USB Loader GX again and it still wants the same cIOS wads the same with Configurable USB Loader. As part of the ModMii package I added NeoGamma and Wiiflow. NeoGamma just wanted to load something of a DVD and Wiiflow just kept showing a picture of the external hard drive connections. Yes it was plugged in the USB connector near the edge.
                I've read the important parts in http://www.digital-kaos.co.uk/forums...-loader-34586/ but that has been going for over 2 years and nothing new to try shows up in there.
                I tried to load Priiloader 0.7 but that didn't work either, you see a list of things its trying to do successfully then at the bottom it shows things that didn't work but it doesn't stop on long enough to read the details, crap programming.
                Anymore useful suggestions CK?
                Keith
                2010 Golf GTD (170)
                • ck-ok
                  • 2592
                  #23
                  try installing IOS58 Installer - WiiBrew then reinstall the homebrew channel and the retry forwarder wad.
