bootmii goes blank
  • eldiablo
    • 27
    bootmii goes blank
    hi folks. just wondering if someone can help me. i softmodded my 4.3e with Letterbomb and everything went fine.only yesterday i went into HBC then bootmii but bootmii didnt load and the screen went blank with the wii blue lights just flashing.the only thing i can think of was i put some files into sd card trying to get a usb loader. can i re install everything through letterbomb? thanks in advance
  • ck-ok
    • 2592
    sounds like you dont have the bootmii folder on your sd card.
    did you delete it or rename it?
    if you dont have it on your sd card or pc then reinstall bootmii with letter bomb exploit and hackmii installer and select prepare sd card and it should rewrite bootmii to your sd card or just grab bootmii folder from the download section
    Digital Kaos - Downloads - Wii
    • eldiablo
      • 27
      thanks for the quick reply so do i have to keep the files in the sd card at all times in the wii? so i just pretend that im going to softmod with letterbomb and follow everything again?
      • ck-ok
        • 2592
        keep the card in all the time,if you have fully modded your wii there is no need to do it again all you need is the bootmii folder on your sd card.
        why do you want to access bootmii?
        if your not fully modded then load letterbomb exploit install bootmii again and make sure you click prepare sd card then you should be ok to continue.
        • eldiablo
          • 27
          Thanks for the advice! Have now got it working and can play games off my usb hdd :-) finally do I clear the sd card and put bootmii in there and leave it in the wii? Thanks again for the advice!!!
          • ck-ok
            • 2592
            no keep all the files on the sd card.
            if everytime you switch the wii on it boots to bootmii then just rename the bootmii folder to bootnew or anything else.
            if it does not boot to bootmii then you dont need to do anything but enjoy your games.
            • Keithuk
              • 2264
              As CK says you probably don't have the bootmii folder on your SD card I had the same problem when I softmodded.
              So the new Letterbomb softmods ok then?
              No bootmii doesn't have to be on the SD at all times you only need it if your saving/restoring the NAND. I would suggest to install PriiLoader 0.7 then you can access BootMii from there plus you can do other useful tweaks with it.
              Keith
              2010 Golf GTD (170)
              • eldiablo
                • 27
                thanks for the advice.Letterbomb is fantasic! so far so good...
                • Ollikola
                  • Sep 2011
                  Thanks guys
                  • jrprice30
                    • Dec 2012
                    thanks, this helped me out too
                    • antbanks51
                      • Jan 2013
                      Love letterbomb. Had the Twilight Hack on an old wii, and love seeing its so much easier now.
