I tryy to install hack with letter bomb and keep getting an error saying wont install bad ios found/ Yes I am on 4.3. I Installed the homebrew channel and tried to download the apps needed to run burnt iso's. Bout halfway through the download of the software my WII froze up and so I reset it. After resetting it , my console kept going into error so I uninstalled the hb and then attempted to re-install it. And my console keeps going to error as soon as I open up letterbomb and attempt to install the HBC
using letterbomb hack mii wont install bad ios foun
Tags: None -
Welcome to the forum.
Well I hope your using a Wii 4.3?
Letterbomb only installs Homebrew so any bad IOS's you've installed is your fault for not following the other 4.3 mods on here.
Which IOS are you trying to install thats coming up bad and for why, USB Loaders?Keith
2010 Golf GTD (170) -
has the wii been hacked before?
is the error non vulnerable iso found?
and like keith says this only works on 4.3 are you sure that is your system menu?
and a load more info would be good.sigpicComment
