fitting a H/D instead of D/D
  • icepick
    • 198
    Just purchased a wii that has a faulty disc drive,my aim is to temp. fit a disc drive, mod the unit & instead of the disc drive fit inside the unit a small hard drive & wire-up to the wii-usb .
    Before I begin this ,has anybody done this or can anyone forsee any problems I may encounter !
    Regards
  • ck-ok
    • 2592
    Regards
    why fit a different drive? you can mod it without a drive.
    and why put hdd inside the unit?
    • bluebottle
      • 71
      Regards
      Its very tight inside the Wii, I cant think of any space free. The mod chip only just fitted. And as CK says, you dont need to if you want to modify it.
      • icepick
        • 198
        ..@ ck-ok thanks for an answer....
        "you can mod it without a drive" ... sorry not keeping up to date on modding ! reading more that's great "news"
        "why put hdd inside the unit? " ... 1."Tidyness (all-in -one!)"
        2.When sleeping over daughter still takes her dvd's with her,infrequently she will also take her H/D. Asked if there was no dvd drive & a H/D were fitted inside instead,would she use it....her answer was yes !
        3. I'm doing No....... Women Logic Jokes
        @ bluebottle ,By Removing the dvd player completly from the unit will not there be enough space for a small H/D ?
        Regards
        • ck-ok
          • 2592
          Regards
          cant see any reason why it wont work give it a go and let us know how you go on.
          • Keithuk
            • 2264
            icepick - you haven't said how old the Wii is or which system menu you are using? Obviously if its less than 4.3 then your going to need a useful DVD in it else you can't softmod it.
            If it is 4.3 then you can use LetterBomb then you won't need a working DVD player you would just use an external HDD.
            Keith
            2010 Golf GTD (170)
            • happy_highlander
              • 3535
              Didn't you read the post from ck-ok. A soft mod can be done without a dvd. Even if a game exploit was required for below 4.3 then surely you would just use nintendo online update to 4.3 then use letter bomb
              • happy_highlander
                • 3535
                Regards
                Before you try and fit a usb powered hdd inside the wii have a look at this list USB Devices Compatibility List - WikiTemp and make sure you get a compatible drive as not all usb only powered drive's work due to the wii not producing enough power from port 0 which if i remember correctly is still the only port you can load hdd from
                • ck-ok
                  • 2592
                  even if he didn't want to update he could still use bannerbomb.
                  Bannerbomb - WiiBrew
                  • Keithuk
                    • 2264
                    Yes I read that but he doesn't say how?
                    Keith
                    2010 Golf GTD (170)
                    • icepick
                      • 198
                      Hi again,the wii that I purchased arrived today,disc drive is faulty which I knew. Unit seems to work & running 4.2E & when connected to the net wants to upgrade !
                      Advice/options/recommendations of what you would do next? (relevant to softmodding)
                      Regards
                      • ck-ok
                        • 2592
                        Regards
                        update it to 4.3 then use http://www.digital-kaos.co.uk/forums...indows-170234/ to mod it
                        • icepick
                          • 198
                          Just to say the modding has gone well. THANKYOU to all that contruted to my questions.
                          When I finish the project I will keep all informed.
                          Regards
