softmii'd wii Failed when formated
  • yas
    • 10
    hi i need help,
    i was is not working, i used letter boom to install homebrew channel and then installed gx usb loader, all was working good, until my son formatted the wii, and know when it boot up it come this page.
    here are some pic of what come up on the tv and what happens when i select them
    i know the pic are not that good, so where is what comes up on the tv screen
    SYSTEMMENU
    HOMEBREW CHANNEL
    INSTALLED FILE
    LOAD/INSTALL FILE
    SYSEM MENU HACKS
    SETTINGS
    ERROR AUTOBOOTING SYSTEMMENU !
    TICKET NOT FOUND!
    ISO V80
    SYSTEM MENU v514 preloader V0.28
    what can i do to get the wii working, any help will be great full
    thanks in advance
  • ck-ok
    • 2592
    welcome to the wii forum
    try reinstalling the homebrew channel again with http://hackmii.com/2011/08/letterbomb/
    then follow http://www.digital-kaos.co.uk/forums...-3-mod-157379/ to get all the ios's and usb loader gx.
    you also need to keep the sd card in.
    • yas
      • 10
      try reinstalling the homebrew channel again with Introducing: LetterBomb (the letter from heaven)
      hi ck ko, thanks for the infroamtion, but i can get into the system menu.
      when i load the wii up i can only got the bit the says the following
      SYSTEMMENU
      HOMEBREW CHANNEL
      INSTALLED FILE
      LOAD/INSTALL FILE
      SYSEM MENU HACKS
      SETTINGS
      TICKET NOT FOUND!
      when i click on systemmenu i can get a error
      it says ticket not found,
      is there any way to get in the systemenu or homrbrew cgannel
      any more help will be great full
      • ck-ok
        • 2592
        SYSTEMMENU
        HOMEBREW CHANNEL
        INSTALLED FILE
        LOAD/INSTALL FILE
        SYSEM MENU HACKS
        SETTINGS
        TICKET NOT FOUND!
        try putting the hackmii installer BootMii.org on your sd card and try and load the boot.dol from the load file appon the priiloader screen this might get you the homebrew channel back.
        • yas
          • 10
          thank Ck i will try when i get home, give an up later on
