I softmeddes wii 4.3E but when i want i want to load some of the games the wii freezes and i have to shut it of and back on this is not with all the games i have problems with call of duty black opps, cars 2, donkey kong country returns, williams pinball classic.
black screen when game loads
That's because you do not have the correct cios version to play those games. how are you trying to load the games, with what loader and what do you have installed on your wii (by that I mean cios versions) best way we can help is for you to post a syscheck. If you don't know what that is try mr google he'll tell you. -
sysCheck v2.1.0b14 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Priilaoder installed
The drive supports DVDs
Homebrew Channel 1.0.8 running on IOS58
Hollywood v0x21
Console ID: 127661377
Boot2 v4
Found 99 titles.
Found 54 IOS on this console. 5 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 257): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[75] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2011/10/31.
I have used cfgloader, wiiflow, coverfloader and usbloadergx for loading the games.Comment
thats not true, the only advantage of downgrading is if you have a mod chip fitted then you would get back multi region playback if you downgraded to 4.1 otherwise it would be pointless.sigpicComment
i've games downloaded that works, maybe ar the iso that i downloaded corrupted, when i select the games in the usbloader i can download the covers and the sound of the games is also playing only when i run the game it freezes to black screen.Comment
When it says The drive supports DVDs I'm assuming thats alot earlier version updated to 4.3? The 3 that I've softmodded don't say that in their syscheck but two of them are 4 years years old.
I haven't bothered with cars 2, donkey kong country returns, williams pinball classic, only Call of Duty: Black OPS and that works on my 3 loaders, there is a fix to get this working on here but I haven't used it.
Yes they could be corrupt downloads try them from somewhere else.
All the loaders will download the images thats part of the loader process of the web.Keith
2010 Golf GTD (170)Comment
All your ios are ok what are you trying to load black ops with. It loads with 250 on gx 2.3 and do not try to use emulated nand it will not work with cod. Same loader but 249 for donkey kong, emu nand does work for this one, and I'm pretty sure all the rest run on 249 same as donkey kong. For uloader cod runs on 224 I think or 223 all the rest run on default 222. I don't use cfg but I'm pretty sure it is the same settings as uloader. The d2x cios pack was developed with gx and works perfectly together.
Edit 223 and 224 have the wrong bases they should be 223 [37] and 224 [57] that is why cod won't work on cfgLast edited by happy_highlander; 31 October, 2011, 21:50.Comment
Did you convert the ISO files to WBFS files? I have forgotten to do so on a couple of occasions and they will sometimes still play the disc intro song and the loader of choice with also download the cover art, but the game is unplayable.
If that is the case, try WiiBackupManager.sigpic
...I Love My Toot-Tone...Comment
Thats an old version m8 I put the new one on yesterday Digital Kaos - Downloads - Wii backup manager 0.4.0 build 65Did you convert the ISO files to WBFS files? I have forgotten to do so on a couple of occasions and they will sometimes still play the disc intro song and the loader of choice with also download the cover art, but the game is unplayable.
If that is the case, try WiiBackupManager.Comment
i copied the iso to hard disk with wii backup manager the latest version i found on this site now i've downloaded more games that work i just think that the iso i downloaded are corruptedDid you convert the ISO files to WBFS files? I have forgotten to do so on a couple of occasions and they will sometimes still play the disc intro song and the loader of choice with also download the cover art, but the game is unplayable.
You have all the correct cios for gx 2.3 use that loading with the numbers I suggested and if they don't work then it is definitely the iso, I am assuming you are downloading them because your original is damaged, because we all know that piracy is not condonedComment
