Neek2o Setup and installation guide
  • NpDump
    • Oct 2012
    #211
    Originally posted by happy_highlander
    Could be file structure, but it is more likely to be that hdd is not formatted correctly. It must be first partition of multiple partition hdd and it must be fat 32 with 32kb clusters and there must be a game iso on the drive or neek2o won't load.
    my harddrive is partition 1 active primary:fat32 cluster 32kb and partition 2 is ntsf primary how ever i dont have a game iso on my drive will .wbfs work or do i need to convert? whats the file path? usb:\games\xxxxxx.iso?
    • happy_highlander
      • 3535
      #212
      The game goes in a wbfs folder that is on the root of the drive and is in wbfs format. Wiibackup manager is the best to add games to fat 32 drive.
      • NpDump
        • Oct 2012
        #213
        k was making sure all of them are correct then idk what my deal is i just get black screen nothing happens waited over a hr nothing is there any signs that neek2o is booting?? disc flashes? my hhd blinks raipdly and then light stays solid after a min or so i just upgraded to 1tb wd my passport and no probs with loading games no spin down issues i know some wd drives do tho.. i know im doing everything right is there any other special wads or anything besides the channel forwarder neek2o_NK2O_1.wad im going to try again on the 320gb wd passport essentials and see what that does
        • happy_highlander
          • 3535
          #214
          re download everything from modmii It only takes one bad file or you could use these Digital Kaos - Downloads - Neek2o without nands but you will have to add your own nand which may be the part that's causing the crash..........Remember this is one of the pickiest setups I have ever come across..
          • fmjvicious
            • 6
            #215
            i am still having issues with this
            • fmjvicious
              • 6
              #216
              It has got to be the hdd. The main issue some folks have been having is that the hdd is slow to start up and neek2o had finished it's checks before the hdd kicks in. There is a workaround by aging a delay into the code in the neek kernel (I think) but it requires adding a new string and the use of a hex editor. Check your pm
              could u plz pm me the same thing with some instructions as im having the same problem
              • fmjvicious
                • 6
                #217
                forget that i got things working however can u tell me how to have 2 nands 1 EU and 1 USA. id like to switch between the 2 depending on which version of the game i have. i currently have the 1 EU nand working
                • happy_highlander
                  • 3535
                  #218
                  Use modmii to build a new nand but choose U instead of E
                  • fmjvicious
                    • 6
                    #219
                    i gave up and started a fresh. just did it with a us nand since i only want this to play tintin which is in ntsc. The trouble now is Tintin show in the disc channel but when i press start in freezes on the wrist strap warning page . can u help?
                    • happy_highlander
                      • 3535
                      #220
                      Sorry can't help with that one. I have eur tin tin working perfectly. If you have a good E setup look in the downloads section and you will find a little program I uploaded that allows you to change the region of an iso. It works perfect on cod so should work with tin tin
                      Here is the link to the region changer thread http://www.digital-kaos.co.uk/forums....php?p=1402004
                      • fmjvicious
                        • 6
                        #221
                        Here is the link to the region changer thread How to change the region or display name of any wii iso
                        Does this mean ill have to go back to an EU nand?
                        • happy_highlander
                          • 3535
                          #222
                          It's up to you all I know is that the pal version of tin tin works perfectly with neek2o and tbh I've never had much luck with any other region online. You do know that joy flow will also run the games but runs them in region free mode. It want very stable in the beginning and I haven't used it since so it may be much better now
                          • Keithuk
                            • 2264
                            #223
                            I've probably said before in this long thread my PAL Tin Tin works for 30 minutes then locks up, you just restart it and carry on.
                            Keith
                            2010 Golf GTD (170)
                            • fmjvicious
                              • 6
                              #224
                              I get the same result when using joyflow. Ill try the ISO region changer on a E setup and see if that works. If not ill have to get my hands on a PAL version of tintin and try that.
                              • SANTIALCALA
                                #225
                                Sorry for my english.
                                I?m interesting in download neek2o without nands for trying in my wii. I?m using uneek without problems but when I run neek20 channel i obtain a black screen and wii hangs. How uneek still works i think that the nands in the USB stick are ok. I suspects d2x v8 ios 249 base 58
