help needed wii remote
  • skegsagypsy
    • Aug 2009
    • 1230
    I decided to update mi wii from 3.2e twilight hack to 4.1e, I followed te tut and after installing the isos my wii remote is refusing to sync, anyone know what to do ?
    'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
    -Bishop Desmond Tutu
  • Fellianis Wig
    • 427
    Pull the flap on the wii down while its turned on , hold the red sync button for 20 seconds let go wait a minute the press it again and hold 1+2 on your remote,if not go back to 3.2 with the nand backup you made with bootmii.You did make a nand backup didn't you?
    • skegsagypsy
      • Aug 2009
      • 1230
      further update...I can sync the wii remote as long as the usb drive is disconnected, then plug usb back in. Another problem though, some games are booting into a black screen and won't play. Problems Problems Problems
      ps...I didn't bother with a nand backup I know that wasn't smart but hey ho I like to live dangerously
      • Fellianis Wig
        • 427
        Ok , sounds like a bad install download modmii install to your pc then follow the on screen instructions and it will prepare a folder with everything you need to put on the sd card and that should solve it.
        • skegsagypsy
          • Aug 2009
          • 1230
          Me again, sorry ok remodded using modmii now the remotes working again, but the usb drives not recognised now and the usb channel reboots the wii as it's loading, on top of that the millionaire game only loads a black screen any further advice much appreciated.
          • skegsagypsy
            • Aug 2009
            • 1230
            ***update***
            I just realised I had configured the usb drive in mdmii to format fat32 and the drive is wbfs, thats why it's not how do I rectify that issue ?
            ***Further Update***
            All sorted. Thanx
