wii cios overview (usb loader freezes)
  • darson
    • Dec 2011
    • 9
    Hi,
    as I installed 236 and d2 cios, i successfully ran one ios fram usb memory stick formatted with wbfs. nest time, i added one more iso on the stick, and after that the usb loader freezes. have used coverfload and cfg. only cfg worked once.
    Is there somewhere you can see a overview of the updated ios'es, i feel like serarching at random... hermes, the 249, d2, different versioons, i get confused...
  • johnb1
    • Dec 2011
    • 82
    hey you can put this on de sd card of your wii
    syscheck 2.0.1
    if you run this , it will make a file that you can read on your pc
    hope i helped you
    johnny
    • Keithuk
      • 2264
      Welcome to the forum.
      Well I use syscheck v2.1.0 Beta 11 posted on here. There is a Beta 14 but I don't like what it tells you.
      Run sysCheck from HBC and post your report in here.
      Keith
      2010 Golf GTD (170)
      • darson
        • Dec 2011
        • 9
        Thanks for the tip - the syscheck reported this:
        Syscheck v2.0.1 by Double_A
        ...runs on IOS58 (rev 6175).
        Region: PAL
        System menu 3.4E (v386)
        Hollywood v0x11
        Boot2 v3
        Found 53 titles.
        Found 27 IOS on this console. 5 of them are stub.
        IOS4 (rev 65280): Stub
        IOS9 (rev 520): No Patches
        IOS10 (rev 768): Stub
        IOS11 (rev 256): Stub
        IOS12 (rev 11): No patches
        IOS13 (rev 15): No patches
        IOS14 (rev 262): No patches
        IOS15 (rev 265): No patches
        IOS17 (rev 517): No Patches
        IOS20 (rev 256): Stub
        IOS21 (rev 522):No patches
        IOS22 (rev 777): No patches
        IOS28 (rev 1292): No patches
        IOS30 (rev 2816): Stub
        IOS31 (rev 3088): No patches
        IOS33 (rev 2832): No patches
        IOS34 (rev 3087): No patches
        IOS35 (rev 3088): No patches
        IOS36 (rev 3090): No patches
        IOS37 (rev 3609): No patches
        IOS50 (rev 4889): No patches
        IOS53 (rev 4113): No patches
        IOS55 (rev 4633): No patches
        IOS58 (rev 6175): No patches
        IOS236 (rev 65535): Trucha bug, ES Identify, NAND Access
        IOS249 (rev 21006): Trucha bug, NADN access, USB 2.0
        IOS254 (rev 65281): BootMii
        BC v5
        MIOS v9
        Does this tell you something about why the Wii freezes when I try to run cfg loader and the coverfloader gets stuck at "Loading textures"?
        Earlier today I managed to run one .iso using a USB memory stick (Corsair Flash Voyager) formatted with WBFS, it worked once, then after I put in another ISO the Wii does not recognize the USB stick at all. The CFG cannot mount the volume (yes, I put it in the slot nearest the corner), as if the usb stick is dead, but it works fine in the PC with WBFS manager...
        • happy_highlander
          • 3535
          Very low version numbers on all ios. Put that syscheck csv file into the update section of modmii and it will download all the new ios and cios versions for you. You then just install then on the wii with your wad manager
          • darson
            • Dec 2011
            • 9
            Sounds like moodmii is the app, where can I download the latest version? Seems like I have been using old links found at random by googling...
            • happy_highlander
              • 3535
              here you go Digital Kaos - Downloads - modmii 4.3.4 this will auto update to the latest version every time you run it and in turn will always download the latest ios files. After you have your system up to date you might want to have a look at http://www.digital-kaos.co.uk/forums...ctions-235450/ to complete your softmod setup...That's if modmii doesn't download the full set for you anyway.
              • darson
                • Dec 2011
                • 9
                Thank you!
                Now it works 100% - I use the softloaderGX, and there is no problem, running from a 32 gb usb stick!
                Merry Xmas to u all!
                • Keithuk
                  • 2264
                  I'm glad your sorted.
                  softloaderGX thats a new one on me, USB Loader GX.
                  Now a 32GB stick won't hold much about 6 games but if your using WBFS then these are compressed more. Have you thought about getting a larger external HDD?
                  Merry Christmas guys.
                  Keith
                  2010 Golf GTD (170)
                  • darson
                    • Dec 2011
                    • 9
                    Hehe, yes I meant usbloader GX. :-)
                    The 32 gb stick was just something I had lying around, I think I will get a 2,5" external HDD, I guess the Wii USB port can supply a 2,5" with voltage via USB so I do not need another power cord...
                    • Keithuk
                      • 2264
                      A 2.5" external HDD should be ok but make sure its mains powered else you could have troubles with these self powered drives. It isn't the voltage 5v its the current draw and the edge USB connector can't supply that much. The other one can but you can't use that one.
                      As I've said before not all external drives work check out which ones do and which don't? USB Compatibility List I've added my 2 drives to that list a while ago.
                      Keith
                      2010 Golf GTD (170)
                      • happy_highlander
                        • 3535
                        As keith says. Make sure your hdd has a power lead as the wii struggles to power an hdd from the usb port. You could end up with a whole host of problems trying to run a usb powered drive
                        • darson
                          • Dec 2011
                          • 9
                          Thanks for the info, prevented me from going into more trouble :-)
                          I will drop the idea about usb-powered 2,5" drive, and go for an ordinary one with power lead...on the plus side, those are cheaper too...
                          • happy_highlander
                            • 3535
                            good choice if you use the list keith linked to you will be able to find a good choice of compatible drives in whatever budget you set yourself.
                            • darson
                              • Dec 2011
                              • 9
                              Hm, now the usb loader freezes again, after I installed more iso's on the usb stick (formatted with wbfs, using wbfs manager 3.0).
                              When I run without usb stick, then comes "waiting for HDD: 20 seconds left" and counting down, when I insert the usb, it freezes.
                              To me it seems like the USB stick is not 100% compatible, a Corsair Flash Voyager 32 GB.
                              Tomorrow I will test using a WD Elements HDD which is NTFS formatted, and see if it works better with a real external disk drive...
