should I update anything on wii
  • icepick
    • 198
    Should I update anything on the wii & if so what do you reccommend ?
    sysCheck v2.1.0b14 by Double_A and R2-D2199
    ...runs on IOS36 (rev 54321).
    Region: PAL
    System Menu 4.3E (v514)
    Priilaoder installed
    The drive doesn't support DVDs
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x11
    Console ID: 52812078
    Boot2 v4
    Found 125 titles.
    Found 47 IOS on this console. 7 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 3867): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5406): No Patches
    IOS55 (rev 5406): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS202[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS249[38] (rev 17): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS250 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2011/12/21.
    Regards
  • Keithuk
    • 2264
    Well my Beta 14 says
    The drive supports DVDs when it doesn't. Yours is saying The drive doesn't support DVDs which mine should say. All the previous versions don't mension this thats why I don't use the Beta 14.
    Your IOS222 to IOS250 aren't the latest dx2 if you want to install those?
    Digital Kaos - Downloads - D2X v7 WAD PACK
    Otherwise if everything is running ok then leave it.
    Keith
    2010 Golf GTD (170)
    • icepick
      • 198
      ThankU sir for the quick reply..
      "Your IOS222 to IOS250 aren't the latest dx2 if you want to install those?" . . . . I shall give these a go !
      "Yours is saying The drive doesn't support DVDs" . . . this may be correct as I replaced the dvd drive ..but I shall look into it further . . .
      • Keithuk
        • 2264
        Thats unusual that you replaced the DVD drive it doesn't seem worth the hassle you may as well buy a new Wii?
        Please try the sysCheck Beta 11 see if it says the same The drive doesn't support DVDs?
        Keith
        2010 Golf GTD (170)
        • icepick
          • 198
          Hi Keithuk ,
          For me it started as a 'saterday-left-alone-at -home' ... impulse ebay purchase (which I 'won'!).. the selller had described unit as 'dvd not working which I didn't mind as I purchase the unit 'cheap-enough' & I had this idea that I remove the faulty dvd & replace with a 2.5 slim h/d inside the unit.
          Unfortunatly the daughteromongst others poured cold water on 'my' idea & other than mod the unit I went no further with 'my-original-project' !
          I then purchase from China a dvd player which came out at 18.1358 EUR including postage-which I thought acceptable, fitted it (piece of cake!) . . . . & that is my 'story' to date !
          for your info I have downloaded & run the sysCheck Beta 11
          and the result is as follows:-
          sysCheck v2.1.0b11 by Double_A and R2-D2199
          Region: PAL
          Hollywood v0x11
          Boot2 v4
          Found 125 titles.
          IOS202[57] (rev 65535, Info: v5.0): Trucha Bug, NAND Access, USB 2.0
          IOS222[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
          IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
          BC v6
          MIOS v10
          Report generated on 2011/12/24.
          Hope this is informative to you,thnkQ for the help & to your -self & others that have helped in the past . . . . .
          SEASONS GREETINGS
          "To find joy in work is to discover the fountain of youth."
          Pearl S. Buck
          • Keithuk
            • 2264
            Ok that Beta 11 don't say anything about the DVD status that ok.
            As I said before your IOS222 to IOS250 aren't the latest dx2 if you want to install those?
            You obviously haven't installed those but if its working ok you should be ok just remember this for future reference?
            Merry Christmas to all.
            Keith
            2010 Golf GTD (170)
            • icepick
              • 198
              . . . "As I said before your IOS222 to IOS250 aren't the latest dx2 if you want to install those?"
              Hi, I couldn't see the IOS222 in the recommended download . .
              All that is contained in the file are:-
              IOS - 245,246,247,248,249,250,251 . . . !
              • happy_highlander
                • 3535
                Use the d2x final wad pack mate ios 222 223 224 are all hermes cios files and are not really required anymore (unless you use uloader) d2x covers all the bases required to run all games and from your syscheck your 222 and 223 are on the same base as 249 making them run the same games. If you look at the numbers in braqckets next to the cios numbers then you will notice they are all different and they refer to the original ios base used to run the different games
                • icepick
                  • 198
                  . . . . "In the land of the blind,there are still those that need to be "hand-held"
                  ThankQ for your answer !
                  PS. . ."we do, as it happens" , use Uloader,does your posting still stand?
                  regards
                  • happy_highlander
                    • 3535
                    regards
                    I'll grab you the relevant hermes cios wads from my nand dump mate
                    • happy_highlander
                      • 3535
                      Okay Icepick here you go Digital Kaos - Downloads - Full Cios wad pack this contains cios 202, 222, 223 and 224 for uloader and media players....I have also included d2xv7 final and mmm. Extract to blank sd and install using mmm through hbc or copy contents of wad folder to wad folder on existing sd and install with your prefered wad manager.
                      • icepick
                        • 198
                        ThnQ for your effort . . . . "this should keep me quite for a bit"
