soft modded 4.3e wii
  • MR-T
    • 53
    #16
    Thought i'd better mention this part of a tut i followed from another site and think thats where i screwed up
    Load Priiloader from Homebrew Channel.
    Once Priiloader has initialized, press and then press to start the installation.
    After finished installing, turn off your Wii.
    Now hold the reset button on your Wii, and press the power button, this will launch Priiloader
    Go to Settings.
    Ensure Autoboot: and Return to: are set to System Menu.
    Change the Background Color to Black.
    Save settings.
    Press and go to System Menu Hacks.
    Enable desired hacks. At minimum i suggest enable Block Disc Updates, Move Disc Channel, and Block Online Updates.
    Save Settings.
    Press and select Homebrew Channel.
    Go to Step 7 - SD Card Clean Up.
    If you want to access priiloader in the future, you can access priiloader using these methods:
    Hold and then press .
    Or change autoboot to priiloader, this will cause Priiloader to load up as soon as your Wii turns on.
    regards
    MR-T
    • ck-ok
      • 2592
      #17
      Go to Settings.
      Save settings.
      Save Settings.
      regards
      MR-T
      if i was you i would use modmii to update your wii select the option virgin install and the option of having a custom tutorial writen for you should take about 10 mins to download and 10mins to mod
      • MR-T
        • 53
        #18
        I have the current modmii 5.0.0 latest version but cannot find the option virgin install to update,can you provide any further assistance.thanks in advance.
        regards
        MR-T
        • ck-ok
          • 2592
          #19
          regards
          MR-T
          start modmii select w option then select rehack wii
          • MR-T
            • 53
            #20
            thanks for getting back to me will give it a try
            regards
            MR-T
            • MR-T
              • 53
              #21
              just another quick question would it be wise to delete all the old files of the sd card and start again from the beginning.
              thanks in advance
              regards
              MR-T
              • Keithuk
                • 2264
                #22
                It depends what files you have on the SD card? If you use USB Loaders you can leave all those.
                Modmii will make add all the files it suggests in the ADD TO SD CARD folder in the Modmii folder so check if any apps in the app folder are new just overwrite them.
                You could remove all the wad files in the wad folder so as not to confuse you when you install them all.
                The choice is yours.
                I just deleted the wads as the MMM was the same version that I use 13.4.
                Keith
                2010 Golf GTD (170)
                • ck-ok
                  • 2592
                  #23
                  thanks in advance
                  regards
                  MR-T
                  i would format the sd card and start from afresh
                  • happy_highlander
                    • 3535
                    #24
                    I agree but would copy the contents to the pc first incase thou need to refer back to the file paths
                    • MR-T
                      • 53
                      #25
                      Thanks to all that helped me out,i am truly greatful for pointing me in the right direction i now have it up and running without any problems.
                      regards
                      MR-T
