Can't load BootMii - screen goes black when app is clicked
  • smithonian
    • Dec 2011
    • 9
    #16
    Nope, that didn't work either. Anything else to try?
    By the way, is all this even on the right path to fix the reason why I can't play Zelda Skyward Sword? Or am I just chasing a lost cause?
    • ck-ok
      • 2592
      #17
      no priiloader wont help you play zelda skyward but its best to take it one step at a time.
      try deleting priiloader redownloading it again and wipe off the priiloader folder from your sd card reinstall priiloader with the hack file in the priiloader folder.
      • smithonian
        • Dec 2011
        • 9
        #18
        By the way, for some reason, even though I wasn't able to have any of this work, I simple loaded Zeldad Skyward Sword through the USB Loader disc loader app, and for some reason it worked! However, on the Wii home screen, it still shows that it needs to do an update with the Zelda disc loaded (??)...don't know why.
        • Keithuk
          • 2264
          #19
          My The Legend of Zelda Skyward Sword works through USB Loader GX with no mods.
          Have you managed to install PriiLoader 0.7 yet?
          Keith
          2010 Golf GTD (170)
          • ck-ok
            • 2592
            #20
            if your on 4.3 then just let it update can't do any harm
            • rivetrik
              • Jan 2012
              does any one have a copy of there boot me files that i can use? id like to have both priiloader and boot mii just to be safe
              • ck-ok
                • 2592
                #22
                welcome to dk rivetrik
                look on the download page Digital Kaos - Downloads - Wii
                • up in here
                  • Jun 2012
                  thank you, the same thing happenned to me
                  • sugerlips
                    • Aug 2012
                    hi im having the same problem
                    • Keithuk
                      • 2264
                      #25
                      There are a few problems in this thread explain your problem don't assume because you have posted in Can't load BootMii - screen goes black when app is clicked that everything is the same?
                      The reason you can't load BootMii is because the [bootmii] folder is missing of the SD card. You can use Modmii to make a new [bootmii] folder.
                      Keith
                      2010 Golf GTD (170)
                      • Jessica12893
                        I have the same problem sorta
                        I have homebrew channel and all and when i got to access my bootmii i click on the launch boot mii and my screen shows the bootmii start up page but at the moment my controller shuts down and my blue light where you insert the disc continually blinks what am i doing wrong???
                        • Keithuk
                          • 2264
                          #27
                          Welcome to DK Jessica.
                          Read other posts in this thread?
                          Originally posted by Keithuk
                          You can't access BootMii because you didn't softmod all three parts correctly you didn't Prepare SD card which makes the [bootmii] folder on the SD card. I've just explained this in the last post in http://www.digital-kaos.co.uk/forums...9/index19.html
                          If the [bootmii] folder is missing you can add it to your SD card with ModMii
                          Once in BootMii the Wiimote doesn't work you have to use the Power, Reset and Eject buttons to navigate and select icons if your trying to do a NAND backup.
                          Keith
                          2010 Golf GTD (170)
                          • mikimokiok
                            #28
                            Ian stated that "hacks.ini goes on the SD card root, hacks_hash.ini goes in the apps\priiloader folder.
                            • Keithuk
                              • 2264
                              #29
                              Yes so whats your problem?
                              Keith
                              2010 Golf GTD (170)
                              • ac0mputerguru
                                Me too
                                Having the same problem...going to try to download the replacement BootMii
