Hi guys I'm new to all softmod on wii's but got my hands on Indiana and used the Indiana pwns exploit everything seems and I have homebrew channel working ***128516; but my question to you guys is can I play my backup games straight off or do I need to add tools or apps to the sd card and where do I get these apps from if so !!any thanks dagz
Hi noob help please
Welcome to the forum dagz.
I bet you didn't do a NAND backup this is the first important job you must do just in case your brick it. If you haven't done this softmod it again and just choose the third option Prepare SD card so you can use BootMii to do the NAND backup. There are tutorials on backing up the NANND on here and installing PriiLoader.Hi guys I'm new to all softmod on wii's but got my hands on Indiana and used the Indiana pwns exploit everything seems and I have homebrew channel working ***128516; but my question to you guys is can I play my backup games straight off or do I need to add tools or apps to the sd card and where do I get these apps from if so !!any thanks dagz
You don't say how old or which version your Wii is. The later Wii's have a different DVD drives so you can't play burnt discs with NeoGamma. Type your Wii serial number into
Wii Drive Chip Database
The main reason for softmodding is so you can play games of an external hard drive with the 3 main USB Loaders. There is a sticky tutorial on here and plenty of threads that talk about them.Keith
2010 Golf GTD (170) -
Hi Keith many thanks for your reply I did a NAND back up(I think) is that when you go in bootmii and do the back up where the green moves across the screen with the odd black one ? Sorry for technical terminology ***128522; our wii is quite old 08/09 I think but will find out and version 4.3e and I'm gonna read your guide on priiloader coz I like knowing stuff Once again many thanksComment
Thats ok dagz not many people know about backing up their NAND. You must save the [bootmii] folder and files in there along with nand.bin and keys.bin of the root of the SD card somewhere very safe.
Yes I would concentrate on getting PriiLoader 0.7 installed to block online and disc updates plus you can do other tweaks. Digital Kaos - Downloads - priiloader v0.7
and I would also do a sysCheck so you can see which IOS's are being used.
Digital Kaos - Downloads - sysCheck v2.1.0 Beta 11
There are plenty of things you can download in the Wii download section on here.
Digital Kaos - Downloads - WiiKeith
2010 Golf GTD (170)Comment
Hey Keith sorry to be a pain in the...
Just read the priiloader guide and ready to do it but remember reading somewhere that you have to install wads first or it will brick the console is this nonsense and just follow your guide you posted mate ***128549;
sorry for being a slack ass newbie ***128522;
Just follow the guide linked to by keith. All the guides on here have been tried and tested many times mate. As said before nand backup and priiloader installation should be the first things done before installing any wads as they are the protection from bricking.Hey Keith sorry to be a pain in the...
sorry for being a slack ass newbie ***128522;Comment
First of do a sysCheck as I've said.
When you install PriiLoader you will see at the top uses IOS58 so you may as well install IOS36 and IOS58. Now I always use MMM 13.4 which in the download section
Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4
Just copy MMM folder from that download into the apps folder on the SD card along with any wad files in the wad folder, make a wad folder on the SD card if you don't have one..
Digital Kaos - Downloads - ios 36 v3608
Digital Kaos - Downloads - ios58-64v6175Keith
I have removed this file and replaced it with the same setup but now has d2x v7 final instead of the beta version Digital Kaos - Downloads - Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4First of do a sysCheck as I've said.
hi mate i have just tried to load your usbloader in multi mod manager but couldnt find ios236 but at the bottom of your read me,it says that it runs on ios249 would i be right in selecting that one instead or do i have to do something different ? many thanksLast edited by dagz; 9 January, 2012, 11:36.Comment
Yes USB Loaders generally use cIOS249 but in that dx2 v7 Final there are all the IOS wads that are used in USB Loaders. For certain games you my need to change the IOS used to another number in the settings for that game.
e.g.
Modern Warfare 3 needs to use IOS250.
In MMM install all the d2x wads then your covered. After each wad is installed you will get an OK message make sure you get the same OK on each wad. If one doesn't install select that wad number again and keep trying until it says OK.Keith
sysCheck v2.1.0b11 by Double_A and R2-D2199...runs on IOS58 (rev 6176).Region: PALSystem Menu 4.3E (v514)Homebrew Channel 1.0.8 running on IOS58Hollywood v0x11Console ID: Boot2 v4Found 82 titles.Found 46 IOS on this console. 17 of them are stub.IOS3 (rev 65280): StubIOS4 (rev 65280): StubIOS9 (rev 1034): No PatchesIOS10 (rev 768): StubIOS11 (rev 256): StubIOS12 (rev 526): No PatchesIOS13 (rev 1032): No PatchesIOS14 (rev 1032): No PatchesIOS15 (rev 1032): No PatchesIOS16 (rev 512): StubIOS17 (rev 1032): No PatchesIOS20 (rev 256): StubIOS21 (rev 1039): No PatchesIOS22 (rev 1294): No PatchesIOS28 (rev 1807): No PatchesIOS30 (rev 2816): StubIOS31 (rev 3608): No PatchesIOS33 (rev 3608): No PatchesIOS34 (rev 3608): No PatchesIOS35 (rev 3608): No PatchesIOS36 (rev 3608): No PatchesIOS37 (rev 5663): No PatchesIOS38 (rev 4124): No PatchesIOS40 (rev 3072): StubIOS41 (rev 3607): No PatchesIOS43 (rev 3607): No PatchesIOS45 (rev 3607): No PatchesIOS46 (rev 3607): No PatchesIOS48 (rev 4124): No PatchesIOS50 (rev 5120): StubIOS51 (rev 4864): StubIOS52 (rev 5888): StubIOS53 (rev 5663): No PatchesIOS55 (rev 5663): No PatchesIOS56 (rev 5662): No PatchesIOS57 (rev 5919): No PatchesIOS58 (rev 6176): USB 2.0IOS60 (rev 6400): StubIOS61 (rev 5662): No PatchesIOS70 (rev 6912): StubIOS80 (rev 6944): No PatchesIOS222 (rev 65280): StubIOS223 (rev 65280): StubIOS249 (rev 65280): StubIOS250 (rev 65280): StubIOS254 (rev 65281): BootMiiBC v6MIOS v10Report generated on 2012/01/08.Last edited by dagz; 9 January, 2012, 13:16.Comment
so will get on with it tomoz and let you guys know how it goes so many thanks to you guys and this winning forum
