help for wii mod
  • worsone
    • Jan 2012
    • 9
    help for wii mod
    hi guys n gals im new here and trying to get my feet
    is there a step by step guide to mod my wii please
  • Keithuk
    • Aug 2010
    • 2264
    Welcome to the forum.
    First of we need to know the current Wii version your using and why you need to softmod it?
    Then we can suggest areas to search for on here.
    Keith
    2010 Golf GTD (170)
    • worsone
      • Jan 2012
      • 9
      hi my wii is 4.3e and i would like to try and run games from a hard drive connected to my wii, i know it can be done so im looking for guidance in doing this
      • happy_highlander
        • Aug 2010
        • 3535
        Use modmii from the downloads section this is a pc program that after answering a few questions about your wii, same ones as keith asked pretty much. You choose full softmod with instructions and this will download all the files you need and write you a tutorial on how to do it.
        • worsone
          • Jan 2012
          • 9
          i have found the software i think but you guys are all sending me to and have found out what to do with it but one thing i must say is when someone says noob it means noob and tech speak does not help
          • happy_highlander
            • Aug 2010
            • 3535
            No problem mate but we get noobs who are new to wii modding but can flash an xbox and noobs who are very computer literate and noobs who think they don't know anything about anything but actually know more than they think...........That said,,,what part do you need help with, we are quite happy to do a complete walkthrough on this forum but most people prefer to try it themselves and jump back in when they get stuck....It is a lot easier than you think it is going to be, if it is the wording you are ot sure about put down a list of what you would like translated and we will break it up into smaller more manageable chunks
            • worsone
              • Jan 2012
              • 9
              thanks happy highlander i have run the software and and ready to work through all the notes supplied on the set up files.
              yes i do know a fair bit but just needed to find out where to start which i have done. can i say a great thanks to all that have helped me so far and when i get stuck i will be back.
              i say again thanks to all.
              i will watch the boards and help all i can
              • happy_highlander
                • Aug 2010
                • 3535
                Just be sure to do a nand backup and install priiloader. Now we don't know how old your wii is but if you get the option install bootmii into boot2 and as an ios if it's a newer wii you will only get the ios option which makes priiloader even more important. Once you get your head round what the different parts mean it's not difficult and modmii has made that bit a whole lot easier.
                • Keithuk
                  • Aug 2010
                  • 2264
                  First of to softmod a 4.3 use LetterBomb and do a NAND backup straight afterwards. NAND backup
                  The ModMii in the download section is 4.3.4 so download ModMii 5.1.1 if you want to use that.
                  You need to install a load of wads so use Multi-Mod Manager v13.4 in the apps folder on the SD card. Along with IOS36 v3608 plus IOS58-64v6175
                  Then you need to install PriiLoader 0.7 to block online and disc updates plus you can do a few more tweaks with it.
                  You want to use a USB Loader so use USB Loader GX there are forwarders in that site so you can have a channel on the Wii menu.
                  Now all the USB Loaders need cIOS249 to work so you may as well install all the wads in d2x v7 Final put them all in the wad folder on the SD card and installed them with MMM.
                  Its also useful to have sysCheck in the apps folder on the SD card so you can check which IOS's are being used. You can also use the sysCheck.csv in ModMii to check for newer wad updates.
                  The final thing is you need a suitable external hard drive preferably a mains powered drive of a suitable size to hold loads of games 500MB. Not all hard drives are suitable. USB Compatibility List
                  Then you should be up and running. Now I've tried to explain this guide as simple as possible but if there is anything you don't understand please ask before cocking things up?
                  Keith
                  2010 Golf GTD (170)
                  • worsone
                    • Jan 2012
                    • 9
                    hi guys i have done well i think but i have one or two questions.
                    1 when i boot up the Wii i get the mod mii installation screen is there a file Ive not removed
                    2 the only way for me to get gx loader to run and get to the usb drive is leave the card in the card reader is this right
                    • ck-ok
                      • 2592
                      leaving the sd card in is normal
                      for keep booting into mmm try renaming the bootmii folder to bootmii old if that dont work hold the reset button in while powering on the wii and you will enter priiloader hopefully from there access priiloader settings and make sure return to system menu is selected then save selection and try rebooting.
                      • worsone
                        • Jan 2012
                        • 9
                        thanks changed the bootmii folder to old now it boots to the wii menu will just have to see what else i can put on the wii thanks again guys for the help
                        • Keithuk
                          • Aug 2010
                          • 2264
                          How come you have to rename the [bootmii] folder on 4.3?
                          Mine is still on there and mine boots to the Wii menu.
                          If he has PriiLoader installed then I would check the boot option in there if its booting to MMM.
                          Keith
                          2010 Golf GTD (170)
                          • happy_highlander
                            • Aug 2010
                            • 3535
                            Yours doesn't auto boot to bootmii if the bootmii folder is not renamed because you don't have bootmii as boot2 only as ios
                            • Keithuk
                              • Aug 2010
                              • 2264
                              True but on a 4.3 you can't install BootMii to boot2, we are both using 4.3.
                              Keith
                              2010 Golf GTD (170)
