need help with getting letterbomb to work
  • stoogefan
    • Jan 2012
    i've fallowed instructions on how to get homebrew onto my wii and end up with the same problem every time. bootmii tells me it can only be installed as a ios, what do i do from here?
  • ck-ok
    • 2592
    welcome to dk stoogefan
    install bootmii as a iso thats normal for newer wii's
    • Keithuk
      • 2264
      Welcome to the forum.
      As CK says BootMii can only be installed as an ISO on the 4.3.
      I hope you installed all 3 options.
      1. Install Homebrew
      2. Install BootMii as IOS
      3. Prepare SD card
      If you didn't Prepare SD card you won't be able to select BootMii as you exit HBC to do a NAND backup which is the first job you do after softmodding. If you didn't choose Prepare SD card go back and softmod it again but only choose Prepare SD card which writes the [bootmii] folder on the SD card.
      The second job is install PriiLoader 0.7 to block online and disc updates, plus you can do other tweaks.
      Then you need to add which USB Loader you want to use there is a sticky tutorial on this subject, USB Loader GX is the best.
      Keith
      2010 Golf GTD (170)
      • ck-ok
        • 2592
        why the random posts everywhere?
        • Keithuk
          • 2264
          I've already said that, what about it?
          Yes I think its these new users trying to get their post count up CK.
          Keith
          2010 Golf GTD (170)
