wiimote / wiimc problem
  • randallflagg
    • 27
    Hi all,
    softmodded with mauifrog (mostly). have hbc, usb gx working fine. Wiimc was working ok until i installed an on-line update a couple of days ago. now wiimc loads but wiimotes (x2) wont work so cant choose movies or adjust settings. have to power off wii and forget about movies. can anyone help ?
    see syscheck below.
    ysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.0/4.1E (v54450)
    Priilaoder installed
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x21
    Console ID:
    Boot2 v4
    Found 115 titles.
    Found 55 IOS on this console. 6 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535 Info: v5.1): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: v0.1): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38] (rev 4 Info: v0.1): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: v5.1): Trucha Bug NAND Access USB 2.0
    IOS236 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS245[55] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS246[53] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS247[37] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS248[56] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS249[38] (rev 21007 Info: d2x-v7final): Trucha Bug ES Identify NAND Access
    IOS250[57] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
  • Keithuk
    • 2264
    If the old Wiimc used to work ok before you did an update put the orignal back on the SD card.
    Thats one update I've never done in the app as I don't use it really even though I do have the Forwarder channel on the Wii menu.
    Keith
    2010 Golf GTD (170)
    • randallflagg
      • 27
      Hi KeithUk,
      I was hoping you'd reply !
      I tried putting an old version back into the apps folder but when i went back into wiimc the "update available" pop-up was there and the wiimotes still wouldn't work, so i couldn't decline the update. I'll disconnect the wifi but the wiimotes not working has me stumped!
      As a matter of interest, what app do you use to play movies ?
      • Keithuk
        • 2264
        Well its strange its making you do an update.
        So your remotes work ok apart from WiiMC?
        I shall have to try my WiiMC 1.2.0 to see if it forces an update.
        Sorry I don't use the Wii for play DVD's as they are poor controls I just use my DVD player. There is MPlayer CE if you want to try that one?
        A few weeks ago I added some games to my friends drive. I plugged it in but the remotes wouldn't work. I tried to resync them but he has chargeable batteries which are part of the battery cover so we had to find some more spare batteries but it still wouldn't sync.
        My friend had poped out for some beers when he came back I said the remotes aren't syncing. He just unplugged the power cable and waited a few seconds and plugged it back in and it synced ok.
        Last weekend he said the remotes aren't working again he unplugged the cable again but they still would sync. He even bought an new sensor bar of eBay ?2.50 and that didn't cure it. I bought the console and a remote over to my house. I plugged it in and synced my remote and it worked perfectly. I put some of my rechargeable batteries in his remote and it synced ok. When I took it back it synced ok.
        I Googled for this problem but not much showed up. Users were holding down both sync buttons for 20 minutes and their fingers were arching but they still wouldn't sync. You only need to press them both for a second.
        Other sites were saying if you're not using your Wii unplug it as its like a mechanical device its wearing all the time its in use, obviously only the DVD player is spinning. They also say don't leave game discs sitting in it all the time if your not using them as that effects certain operations.
        His Wii is always on 24\7, not anymore.
        Keith
        2010 Golf GTD (170)
        • Keithuk
          • 2264
          Ok I've run my WiiMC 1.2.0 and it said there is an update available the options were update now or update later I updated it to 1.2.2. It did a restart and the remote still worked
          I'm not sure why your remote doesn't work with WiiMC?
          Keith
          2010 Golf GTD (170)
          • randallflagg
            • 27
            re-installed old version last night and the wiimote came back to life. performed the update just to see what would happen - restarted and all ok ! Dunno what was going on ! I didn't do anything different from a few days ago so the problem seems intermittent.
            I read on another site about wiimotes purchased after Nov 2011 giving problems while trying to work with homebrew apps so that must be it.
            I installed Mplayer CE as a back-up to WiiMC but it doesn't have the same ease of use so I'll stick with WiiMC for as long as I can.
            Thanks for your replies & sorry for wasting your time.
            • Keithuk
              • 2264
              Don't worry your not wasting our time if you have a problem thats what forums are for, I'm glad its working ok for you now.
              When I installed the Mplayer CE Forwarder channel it shows but it doesn't work it just locks up, not that I'm that bothered as I don't use it.
              Keith
              2010 Golf GTD (170)
