Mod Wii with Letterbomb etc
  • pabwal
    • Jan 2012
    • 12
    Hi just tried to help my froend with his Wii 4.3E, we ran letterbomb all went well and then ran through the various things thorugh mod mii. everything seems ok although we did ask it to convert to red theme and it must have missed this.
    Anyway plays normal games fine, when we put in a back up game (via disc),it comes up, click start then an error message, power off and eject disc.
    Have i missed something simple? or will it not work with Discs only HDD?
    its a white Wii not a new one on 4.3E
    cheers
  • happy_highlander
    • 3535
    cheers
    put your serial number in here Wii Drive Chip Database as long as your drive is not a D3-2 you will be able to use discs if it is then hdd is the only option. By the way hdd is the prefered option for a number of reasons. Most importantly is the wii can only read dvd-r at 3x speed while an original disc is read at 6x speed so you may experience some lag and you will definately have problems loading ghostbusters (this requires you to have very precise timing with the eject button)
    • Keithuk
      • 2264
      Your talking about playing burnt games?
      As HH says the newer Wii's won't play burnt games.
      So you softmoded ok you did all 3 stages and you did a NAND backup NAND backup which is the first job after softmodding and installed PriiLoader 0.7.
      Keith
      2010 Golf GTD (170)
      • pabwal
        • Jan 2012
        • 12
        wii
        ok will get him to check the drive, i did mine fine but it was running 3.2 and runs discs although with lag on some, going to change to USB loader soon.
        yes always do a nand back-up Keith, as per the instructions.
        is it on the wii itself the drive number?
        • pabwal
          • Jan 2012
          • 12
          sorry just read your message again , will check serial
          • pabwal
            • Jan 2012
            • 12
            ok it came up with
            • There is a 75% chance the chipset is GC2-D2B (no cut pins or missing pad).
            • And there is also a 25% chance the chipset is GC2R-D2A.
            • Keithuk
              • 2264
              If it was a 3.2 then it should play burnt discs.
              Are you using NeoGamma R8 or R9?
              Keith
              2010 Golf GTD (170)
              • pabwal
                • Jan 2012
                • 12
                sorry i am confusing things now, my one was a 3.2 and it works fine with disc playback. My friends was a 4.3E before we softmodded it.
                • happy_highlander
                  • 3535
                  ok it came up with
                  Did it tell you year of manufacture, if it's before 2008 then it will support dvd as they didn't launch the new chipset until the black wii was released.
                  • Keithuk
                    • 2264
                    My 2009 white Wii won't play burnt games so it doesn't have to be a black one.
                    Yes you are confusing things your is a 3.2 the one you modded was a 4.3.
                    Keith
                    2010 Golf GTD (170)
                    • happy_highlander
                      • 3535
                      I know it doesn't have to be black.....What I said was they didn't introduce the new chip until around the the time the black wii was released
