Fat 32 Formatter
  • icepick
    • 198
    Fat 32 Formatter
    This may be of use to wii users.
    In Wii Upload section. (2 versions in zip file)
    I have used this with sucess to-day to format my 1TB 2.5" portable drive
    Please take care when using . . No responsibilty taken !
    Fat32Formatter is freeware and written by TOKIWA to format drive larger than 32GB to FAT32,
    which means it can walk around the OS restriction that you can format drive to FAT32 only the size up to 32GB on Windows2000/XP/Vista/7.
    Compatible operating systems
    Key-features
    1 simple and instructive UI
    2 it can set and delete partitions as well
    3 neither installation nor DLLs is needed
    4 Windows 7 supported
    How to use
    You can understand it intuitively through simple UI and balloon tips. So there is no need for instructions.
    Also you can update Fat32Formatter to new version if available through "Version info" of system menu.
    Install/Un-install
    Fat32Formatter doesn't need to be installed. Just unpack the archive you downloaded and it's runnable.
    Fat32Formatter doesn't install anything, so neither registry entries nor initialization files are left on your computer once you delete the directory of Fat32Formatter.
    Link . . . http://www.digital-kaos.co.uk/forums...ormatter-2019/
  • Keithuk
    • 2264
    Well you can easily format a drive FAT32 with EASEUS Partition Master its free.
    With the newer versions of the USB Loaders they can use FAT32, NTFS or WBFS formatted drives.
    Some users have a problem formatting the SD card FAT32, I've never had this problem in Windows so they are told to use sd card formater
    Keith
    2010 Golf GTD (170)
    • icepick
      • 198
      . . . . Re-up
      • Keithuk
        • 2264
        Sorry icepick it wasn't a complaint I was just showing another method, stick your file back the users can compare.
        EASEUS Partition Master is in the download section.
        Keith
        2010 Golf GTD (170)
        • icepick
          • 198
          No Problem Keithuk . . re-uploaded... Bad Hair day ,Three times to-day I had, in my own mind, taken the trouble to assist strangers,and only afterwards decided that I could have directed my 'time' to better things.
          I still wonder if the stranger who's wife broke the car-ignition-key is still stranded in Tesco' car park !
