wii softmod issues...please help
  • davidk
    • Feb 2012
    • 4
    so a while back i used lotterbomb to softmod my wii. and like most noobs i had some issues with certain games not loading and things like that. basially i have screwed around and played with the ios's and other game sensitive settings that a lot of the time when i try to load some games it just sends me back to the main system menu. in the mean time i did a softmod to my girls wii using letterbomb and modmii which seems to work flawlessly. my question is how can i go about either removing the softmod from my wii all together or make it so that i can use modmii to reload all the necessary files so that it will work properly. any help will be greatly appreciated.
  • johnb1
    • Dec 2011
    • 82
    i think that you just can start all over from the beginning
    and that all the new things will overwrite the stuff thats
    now on your wii
    • ck-ok
      • 2592
      use modmii again choose su to update your mod all the info you need is in the modmii tutorial as you know
      • Keithuk
        • Aug 2010
        • 2264
        So which games don't work all of them or just some?
        There is no need to unsoftmod it just install the correct wads needed for USB Loaders d2x v7 Final.
        To use the SU option you need sysCheck running to produce a sysCheck.csv file on the computer.
        Post your sysCheck report as intructed in the link so we can see which IOS's are installed?
        Keith
        2010 Golf GTD (170)
        • ck-ok
          • 2592
          when he selects su it will tell him how to do syscheck and what to do with it when he has it
          • davidk
            • Feb 2012
            • 4
            which games don't work...
            originally it started with cod mw3 kept on freezing up. I was fortunate enough to have been able to get some help from here about what ios needed to be loaded and with what base. and i was able to fix it and it works flawlessly. but as i acquired more games i have run into a few that just either won't load all together or freeze up shortly after the game starts. they are:[LIST][*]Splinter Cell Double Agent- won't load at all
            • Hawx 2- loaded a couple of times, now it gets as far as choosing my saved game and freezes.
            • Driver: SF-Loads but keeps freezing mid way through
            • Brunswick Bowling-has always worked fine but tonight all of the sudden won't load.
            could it be possibly the fact that when i modded my wii, i didn't use a program like modmii or anything. i was having a hard time finding files that had instructions that i could understand so i sorta pieced the whole process together. i will post my syscheck and let you guys take a look at it.
            • davidk
              • Feb 2012
              • 4
              here is my syschck file
              sysCheck v2.1.0b17 by Double_A and R2-D2199
              ...runs on IOS236 (rev 65535).
              Region: NTSC-U
              System Menu 4.3U (v513)
              Priiloader installed
              Could not detect the drive date!
              Homebrew Channel 1.0.0 running on IOS58
              Hollywood v0x21
              Boot2 v4
              Found 186 titles.
              Found 55 IOS on this console. 4 of them are stub.
              IOS3 (rev 65280): Stub
              IOS4 (rev 65280): Stub
              IOS9 (rev 54321): Trucha Bug
              IOS10 (rev 768): Stub
              IOS11 (rev 54321): Trucha Bug
              IOS12 (rev 269): No Patches
              IOS13 (rev 273): No Patches
              IOS14 (rev 520): No Patches
              IOS15 (rev 257): Trucha Bug, ES Identify, Flash Access, NAND Access
              IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
              IOS17 (rev 775): No Patches
              IOS20 (rev 54321): Trucha Bug
              IOS21 (rev 782): No Patches
              IOS22 (rev 1037): No Patches
              IOS28 (rev 1550): No Patches
              IOS30 (rev 54321): Trucha Bug
              IOS31 (rev 3608): No Patches
              IOS33 (rev 3091): No Patches
              IOS34 (rev 3348): No Patches
              IOS35 (rev 3608): No Patches
              IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
              IOS37 (rev 5663): No Patches
              IOS38 (rev 4124): No Patches
              IOS40 (rev 16174): Trucha Bug, NAND Access
              IOS41 (rev 3607): No Patches
              IOS43 (rev 3607): No Patches
              IOS45 (rev 3607): No Patches
              IOS46 (rev 3607): No Patches
              IOS48 (rev 4124): No Patches
              IOS50 (rev 16174): Trucha Bug, NAND Access
              IOS51 (rev 4864): Stub
              IOS52 (rev 16174): Trucha Bug, NAND Access
              IOS53 (rev 5406): No Patches
              IOS55 (rev 5406): No Patches
              IOS56 (rev 5662): No Patches
              IOS57 (rev 5919): No Patches
              IOS58 (rev 6176): USB 2.0
              IOS60 (rev 54321): Trucha Bug
              IOS61 (rev 5662): No Patches
              IOS70 (rev 54321): Trucha Bug
              IOS80 (rev 54321): Trucha Bug
              IOS90 (rev 54321): Trucha Bug
              IOS202[60] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
              IOS222[38] (rev 65535, Info: hermes-v5.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
              IOS223[37] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
              IOS224[60] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
              IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
              IOS245[37] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
              IOS246[38] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, ES Identify, NAND Access
              IOS247[53] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
              IOS248[55] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
              IOS249[57] (rev 19, Info: rev 19): Trucha Bug, NAND Access, USB 2.0
              IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
              IOS251[58] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
              IOS254 (rev 65281): BootMii
              BC v6
              MIOS v10
              Report generated on 2012/11/03.
              • happy_highlander
                • Aug 2010
                • 3535
                D2x is a little outdated but new enough to run all the afore mentioned games so it is not that you don't have the correct ios versions you must have the wrong ones selected for ribbing the games. You haven't said what loader you are using but it may be worth removing all traces of it and installing the latest version from scratch
                haha just noticed you have both ios 249 & 250 running with a base of 57 249 should be 56. I just uploaded d2x v8 final last night so grab that and install them straight over the top
