Problems with HDD
  • trentsta
    • May 2012
    • 9
    #16
    Hi guys,
    I have used all 3 USB loaders through HBC and via channel (if I had it) for both the WD passport and a mains USB which was also on the list. I then tried using a USB flash drive and still the same problem. I did a system check with the newer update and checked this in modmii and it said that the wii was all up to date. I think I'm gonna leave at that for now and just keep to using dvd-r's. If any one has any bright ideas let me know. Here's my latest system check:
    sysCheck v2.1.0b17 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x11
    Console ID: 71835145
    Boot2 v4
    Found 92 titles.
    Found 54 IOS on this console. 3 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2012/05/12.
    • happy_highlander
      • 3535
      #17
      Your syscheck is fine mate. Remember you must have at least one game file on the drive as .wbfs file....if drive is formatted to wbfs the game must be on the root of the drive. If drive is formatted to fat 32 the .wbfs game file must be inside a folder named wbfs that is on the root of the drive. Just make sure hdd is plugged into the outermost usb port and try turning on hdd before starting loader, if it doesn't work that way start loader then wait until prompted before switching on hdd. The second method is the only way I could get gx to recognise an old internal drive in a caddy.
      • happy_highlander
        • 3535
        #18
        I've just read the whole thread again and it sounds like the usb port may be faulty. Do you have anything that you know works you can plug into it....i.e. Mic, balance board or band instruments. That kind of thing, just to make sure it is working.
        • trentsta
          • May 2012
          • 9
          #19
          I presume the port is working because I loaded the cfg loader on an apps folder from the HDD drive
          • happy_highlander
            • 3535
            #20
            That's ok then if hbc is recognising the apps folder then the port will be ok, so that just leaves the way the hdd is set up as your syscheck is ok. I'm aware you have tried both wbfs and fat 32. At this stage if I was confident that I had setup the hdd with the correct file structure, I would be running modmii and downloading a new set of files for full softmod wizard, then follow it from after letter bomb (hackmii) and start by making a nand backup which I presume you don't have if you bought it softmodded, then follow the instructions from loading hbc and reinstall everything including hbc, this is the only way you can rule out a corrupt ios file. Don't forget to do a nand backup first if you don't already have one, even though you can't get usb to work it will still provide you with a chance to recover from bricking should anything go wrong which it won't if you follow the instructions. Good luck...If you get stuck just shout up
            • oingo
              • Jun 2012
              having issues w/ config usb loader running some games on hdd have ios56 slot 248; ios 57 slot 247. do i need ios 37 in slot 224?
              • happy_highlander
                • 3535
                #22
                You would need to say what games but it sound as though the ios your missing is cios 224(37+38) or any cios slot not necessarily 224 as long as ios 37 is merged with 38
                • Keithuk
                  • 2264
                  #23
                  He doesn't say which Wii version he has?
                  He can try installing these Digital Kaos - Downloads - Full Cios wad pack
                  Keith
                  2010 Golf GTD (170)
