unlock Wii
  • Ferraz
    • May 2012
    • 4
    unlock Wii
    hello, okay?
    Help!
    I would like to know how to properly unlock Wii 4.3 E.
    I have already installed the homebrew, but I can not do anything else when trying to install usb loader asks cios222 ... or screen goes black! can anyone help? I tried to install the wad manager and wii command blocks. I think the ideal is to return to the beginning? Make a reset?
    Thank you!
    Anular edi??es
  • Keithuk
    • 2264
    Read your other post.
    Keith
    2010 Golf GTD (170)
    • Ferraz
      • May 2012
      • 4
      Helppppppppppppppp!
      I tried to install ios 250 mm with the wii but the blocks.
      I have just ios58?
      I have spent hours and hours on it and nothing!
      In the zx spectrum was everything easier!
      Thanks,
      • Keithuk
        • 2264
        Again read your other post.
        Keith
        2010 Golf GTD (170)
        • Ferraz
          • May 2012
          • 4
          Great!
          HI,
          After much reading ... I can play on the Wii with 500GB external disk.
          I just can not insert a disc? Any suggestions?
          Thank you!
          • Keithuk
            • 2264
            Are you talking about original discs or burnt discs?
            It depends how old your Wii is as Wii's from 2009 won't play burnt discs. Type in the Wii serial number into Wii Drive Chip Database.
            It would help if you posted a sysCheck as instructed so we can see if any other wads are missing.
            Keith
            2010 Golf GTD (170)
            • Ferraz
              • May 2012
              • 4
              Update?
              when I insert an original disc says:
              In order to use this software, you must perform a Wii system update.
              Select OK to begin update.
              What do I do? yes or no?
              Thank you,
              Ferraz
              • happy_highlander
                • 3535
                Thank you,
                Ferraz
                Depends on whether or not you have priiloader installed and whether or not you want to keep your softmod. If priiloader is set block updates selecting yes will do nothing, if you don't have priiloader set to block updates then selecting yes will remove the softmod by performing a system update. Use neogamma to safely run original discs that want to update. You will find version 9 in the downloads section
                • Keithuk
                  • 2264
                  Which game disc are you talking about I need the name?
                  HH as explained about the PriiLoader function which you should have installed after softmodding. It appears you followed a inadequate softmodding procedure.
                  Keith
                  2010 Golf GTD (170)
                  • macwayda87
                    • May 2012
                    cant unmodd wii
                    I've been trying to find a way to start the mod from scratch
                    • Keithuk
                      • 2264
                      We need a bit more info on your system?
                      A Wii 4.3 is a doddle with LetterBomb but that will ONLY softmod the Wii. Now the reason you softmod a Wii is so you can play burnt games of a disc with NeoGamma or games added to an external hard drive with one of the USB Loaders. Using burnt games is alot more expensive as you have to buy quality DVD-R discs then you need somewhere to store them all.
                      The better way is off a mains powered USB external hard drive, there are plenty of thread on here that talk about those.
                      You can also use ModMii and build your own files up but they don't give you anything to do with USB Loader GX which to me is the best USB Loader.
                      Keith
                      2010 Golf GTD (170)
