have you followed the tutorial that modmii downloads for you as instructed in the earlier post from after installation of hbc. look at what you have transfered to the blank sd card you should have bootmii, wads and apps. obviously you don't need bootmii as yoiu are already softmodded so you need to copy the apps and wads folder apps will have mmm and any loaders you have chosen wads will have all the 4.3 system wads and whatever channels you have chosen to install plus a few cios remember the apps and wads folders must be on the root of the sd card
trying to play newest games on 4.1e
i copy everything which was downloaded by modmii it didnt include app, bootmii or any loadershave you followed the tutorial that modmii downloads for you as instructed in the earlier post from after installation of hbc. look at what you have transfered to the blank sd card you should have bootmii, wads and apps. obviously you don't need bootmii as yoiu are already softmodded so you need to copy the apps and wads folder apps will have mmm and any loaders you have chosen wads will have all the 4.3 system wads and whatever channels you have chosen to install plus a few cios remember the apps and wads folders must be on the root of the sd card
all there it got was wads, mmm config file plus guide
ive just tried to download everything again it comes out with the same stuff no apps or loadersComment
highlander can you download files off modmii for them post on here as i cant get them all (attached log showing what i got after 4 times )Attached FilesComment
Ok you are on 4.1e and want to finish on 4.3e yes do you need wii speak and weather channels or are you not bothered. I'll set the files up if you tell me what you wantComment
I will do m8 then I'll send you a pm with a link to my dropbox as the files will be too big to load on here. Ill add all the extras you need as far as cios goes and neogamma 9 with forwarder channel so if you delete the neogamma forwarder you have now that would be handy. I'll also include your tutorial and tell you where to start from..You already have a nand backup don't you.Comment
completed the hack you sent me and older games are working again but newer ones still aint working
i start neogamma up load game then the health screen comes up straight after the messages comes up cant read disc please refer to manual, so i eject the disc it says please insert game, i do starts loading again and spilts out message again
this only happens for newer games old ones like deal or no deal work fineComment
Are you using verbatim dvd- (minus) r.......they are the only ones that work properly. At least you are back to where you were before you done the other update, I am positive you will find it is a disc issue. They MUST be minus r not plus rcompleted the hack you sent me and older games are working again but newer ones still aint working
sysCheck v2.1.0b18 by Double_A and R2-D2199...runs on IOS58 (rev 6176).Region: PALSystem Menu 4.3E (v514)Drive date: 2006.09.07Homebrew Channel 1.1.0 running on IOS58Hollywood v0x11Console ID: 46419846Boot2 v2Found 99 titles.Found 53 IOS on this console. 3 of them are stub.IOS4 (rev 65280): StubIOS9 (rev 1034): No PatchesIOS10 (rev 768): StubIOS11 (rev 16174): Trucha Bug NAND AccessIOS12 (rev 526): No PatchesIOS13 (rev 1032): No PatchesIOS14 (rev 1032): No PatchesIOS15 (rev 1032): No PatchesIOS16 (rev 61234): Trucha Bug ES Identify Flash Access NAND AccessIOS17 (rev 1032): No PatchesIOS20 (rev 16174): Trucha Bug NAND AccessIOS21 (rev 1039): No PatchesIOS22 (rev 1294): No PatchesIOS28 (rev 1807): No PatchesIOS30 (rev 16174): Trucha Bug NAND AccessIOS31 (rev 3608): No PatchesIOS33 (rev 3608): No PatchesIOS34 (rev 3608): No PatchesIOS35 (rev 3608): No PatchesIOS36 (rev 3608): No PatchesIOS37 (rev 5663): No PatchesIOS38 (rev 4124): No PatchesIOS40 (rev 16174): Trucha Bug NAND AccessIOS41 (rev 3607): No PatchesIOS43 (rev 3607): No PatchesIOS45 (rev 3607): No PatchesIOS46 (rev 3607): No PatchesIOS48 (rev 4124): No PatchesIOS50 (rev 16174): Trucha Bug NAND AccessIOS51 (rev 4864): StubIOS52 (rev 16174): Trucha Bug NAND AccessIOS53 (rev 5663): No PatchesIOS55 (rev 5663): No PatchesIOS56 (rev 5662): No PatchesIOS57 (rev 5919): No PatchesIOS58 (rev 6176): USB 2.0IOS60 (rev 16174): Trucha Bug NAND AccessIOS61 (rev 5662): No PatchesIOS70 (rev 16174): Trucha Bug NAND AccessIOS80 (rev 16174): Trucha Bug NAND AccessIOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND AccessIOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND AccessIOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0IOS254 (rev 65281): BootMiiBC v5MIOS v10Report generated on 2012/07/04.
yes using verbatium minus r discs i nver use plus r ones as i know they ruin laserLast edited by pspmixer; 4 July, 2012, 15:44.Comment
No you haven't followed instructions open it with WordPad not NotePad.
Converted:
Region: PAL
Hollywood v0x11
Boot2 v2
Found 99 titles.
BC v5
MIOS v10
You have an early drive so it should play burnt discs but its not advisable.Keith
2010 Golf GTD (170)Comment
I don't need to see that anyway keith I provided all the ios wads so know what's on it, but I would like to know what games won't work from disc as there are a few that have issues loading from disc but not from hdd, I also provided an alt dol for neogamma for a few of the most common problem gamesComment
donkey kong country returns, mario sports mix, new sonic and mario, mario party 9, the amazing spiderman and lego batman 2I don't need to see that anyway keith I provided all the ios wads so know what's on it, but I would like to know what games won't work from disc as there are a few that have issues loading from disc but not from hdd, I also provided an alt dol for neogamma for a few of the most common problem gamesComment
Well
Mario & Sonic London 2012 Olympic Games - NTSC - SIIE8P
Mario Party 8 - PAL - RM8P01
Mario Party 9 - PAL - SSQP01
Spider-Man: The Edge of Time - PAL - SQMP52
all work with USB Loaders so cut your losses an get an HDD.Keith
