Wii system up date
  • ocrim
    • 107
    Wii system up date
    Hi, i have a wiikey2 in my wii, i have a game and all the time i insert the disc the up date wii system appear, i need to click ok or not???please help....
  • dell_xps
    • 2558
    It will be ok to update, you'll be running 3.3 or that, it will be wanting you to update to 3.4 thats all, is the game PAL ?,
    if not then I'd load the homebrew channel and use Gecko to launch it, or search the forum threads how to take out the update from the game.
    HTH
    • DiddyDave
      • 213
      Most games don't need the Wii update if you are already on firmware 3.3 or so so download the Wii Brick blocker before writin g the ISO to disk this will remove the update from the ISO.
      Check the downloads section you will find the BrickBlocker there.
      • ocrim
        • 107
        Hi, Dell can you help to take out the up date from the disk??? please??? i do not have homebrow only wiikey2, the game in question it's animal Crosing..How i know the version of mi wii???
        Thankyou for the help
        • ocrim
          • 107
          Diddi can you tell me thewiibrick... work??? After BEENN download.... thank you
          • dell_xps
            • 2558
            On the main window,select the WII button bottom left, go to settings on the right, look at the top right it will tell you what version you are on.
            3.1, 3.2 or 3.3
            Wii blocker
            • ocrim
              • 107
              Hi Dell, the version it's 3.4E and the game it's Pal" based on the torrent link"(animal crossing), i steel need to use that program???
              Thank you
              • dell_xps
                • 2558
                Thank you
                2008-12-03 Wii Animal Crossing Lets go to the City (c) Nintendo *PAL* LOCAL 94x50 MB 0
                2008-11-16 Wii Animal Crossing City Folk (c) Nintendo *NTSC* GOOMBA
                Any of these look like the one you d/l ?
                • dell_xps
                  • 2558
                  If you have a wiikey v2, download the config disc from there website, burn it to disc,it will see the disc as a gamecube disc you can set the drive speed etc with this disc,you need to go into the options and select that it only lets you update PAL updates.
                  Another option to keep you safe.
                  • ocrim
                    • 107
                    Hi on my file iso saide only animal crossing wii
                    • dell_xps
                      • 2558
                      Resources :: Wiikey
                      Euro version, download and burn to disc.
                      Load it up and select it only accepts PAL updates ok.
                      • dell_xps
                        • 2558
                        Download wii brick blocker, put your iso into that prog it will tell you if it's a PAL game or NTSC, if PAL your good to go.
                        • ocrim
                          • 107
                          hi in wii brick saide it's pal
                          • dell_xps
                            • 2558
                            Ok your good to go !
                            • ocrim
                              • 107
                              I need to pach the file first and after burn on dvd???
