modern warfare 3 online update
  • iphonic
    • 244
    I have a soft modded wii on 4.3e and tried to play Online with modern warfare 3 but it says I need to install a Online update through the game first before I can play on multi player, the message I get is -
    An update to call of duty modern warfare 3 is available. To play this game on MW3 Online you must download it. Download update now?
    open blocks - 925
    blocks to download - 46
    blocks after download 879
    YES
    NO
    by updating the game to play Online will this in any way affect my soft mod? I thought I would ask first as I don't want to loose my soft mod.
    Im running a external hdd with the game files on it.
  • happy_highlander
    • 3535
    open blocks - 925
    YES
    NO
    MW3 Online update is for gameplay only and not a system update....Perfectly safe mate and must be done to allow online play
    • iphonic
      • 244
      Nice 1, quick question do you know how i can get my black ops online running it keeps saying please wait when i try to go and find a multi player game, when i go to zombies online itsays update is required to play the game online switch to multiplayer to update, so when i go to multiplayer which takes me out of zombies and into the normal multiplayer mode no update appears like mw3 did.
      • happy_highlander
        • 3535
        Black ops is the same it should give you an update option
        • iphonic
          • 244
          It doesnt give me the option thats whats confusing, its a NTSC region iso would i need a PAL iso seen as my wii is from the UK? Could that be the problem do you think?
          • happy_highlander
            • 3535
            It really shouldn't matter if priiloader is set to region free but it is the only reason it won't work
            • iphonic
              • 244
              Thats what i thought n my priiloader is set to region free its strange, im guna try a pal version and see what happens
              • iphonic
                • 244
                fix for black ops wii online
                tried this still no luck
                [ame="http://www.youtube.com/watch?v=9ocV0qqyEW0"]Wii Black Ops Fix, Region, Online Update and Connection FIX NEW LINKS - YouTube[/ame]
                • happy_highlander
                  • 3535
                  I think I pulled the black ops download from an extracted nand to set up on neek2o then packed it up as a wad. If I have I'll dig it out and upload it for you to try. It works on my wii and on simulated nand in neek2o but I cannot guarantee it will work or even be harmless on your wii so you will have to use it at your own risk, it should be perfectly safe but I can never guarantee anything when adding wads to your nand
                  • iphonic
                    • 244
                    Cheers mate, im really new to this and all i know is how to install the games from iso or wfsb frmat to my hard drive and play it through configurable usb loader or neogamma etc
                    • happy_highlander
                      • 3535
                      Ok here you go Digital Kaos - Downloads - Black ops Download content for online play but remember I take no responsibility for any bricks caused by files provided by me. This download content was pulled from my original nand and packed into a wad before installing into an emu nand with the same console id, it worked perfectly so should be ok to use
                      • iphonic
                        • 244
                        Cherrs but i doubt i will do it just incase if i find my faulty wii i had from ages bk i mite try it on that one insted first so if it gets bricked it dont matter
                        • happy_highlander
                          • 3535
                          I very much doubt that it will brick the wii but I have to warn you that it might. If you have bootmii as boot 2 and a working nand backup just go for it, to find out if bootmii is boot 2 turn the wii on WITHOUT a disc in and if the drive light flashes twice you have bootmii as boot 2 which makes it almost impossible to brick the wii, except for a hardware issue.
