Never thought I would ask ... 4.3E Freeze!
  • Rookiepno
    • Jul 2012
    • 4
    Hey Pro's,
    I have a problem :-/
    2 Weeks ago I bought a Wii (4.3E) and started to mod.
    I used the Modwii 6.1.5 by Wizard by XFLak .. and it works !!
    The Wii is open for business !!
    Only thing is ... not one backed up game is loading (USB Loader GX 3.0) ... All games freeze, either when starting up or after the title screen.
    After 2 weeks searching and trying, my son gets nervous :-).
    I hope, at least one of you experts can help this newbie.
    Here the sysCheck ...
    sysCheck v2.1.0b17 by Double_A and R2-D2199 ...runs on IOS58 (rev 6176).
    Region: PAL System Menu 4.3E (v514) Priiloader installed Drive date: 2010.12.07 Homebrew Channel 1.0.0 running on IOS58 Hollywood v0x21 Console ID: 158001969 Boot2 v5 Found 98 titles. Found 55 IOS on this console. 4 of them are stub.
    IOS3 (rev 65280): Stub IOS4 (rev 65280): Stub IOS9 (rev 1034): No Patches IOS10 (rev 768): Stub IOS11 (rev 16174): Trucha Bug, NAND Access IOS12 (rev 526): No Patches IOS13 (rev 1032): No Patches IOS14 (rev 1032): No Patches IOS15 (rev 1032): No Patches IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access IOS17 (rev 1032): No Patches IOS20 (rev 16174): Trucha Bug, NAND Access IOS21 (rev 1039): No Patches IOS22 (rev 1294): No Patches IOS28 (rev 1807): No Patches IOS30 (rev 16174): Trucha Bug, NAND Access IOS31 (rev 3608): No Patches IOS33 (rev 3608): No Patches IOS34 (rev 3608): No Patches IOS35 (rev 3608): No Patches IOS36 (rev 3608): No Patches IOS37 (rev 5663): No Patches IOS38 (rev 4124): No Patches IOS40 (rev 16174): Trucha Bug, NAND Access IOS41 (rev 3607): No Patches IOS43 (rev 3607): No Patches IOS45 (rev 3607): No Patches IOS46 (rev 3607): No Patches IOS48 (rev 4124): No Patches IOS50 (rev 16174): Trucha Bug, NAND Access IOS51 (rev 4864): Stub IOS52 (rev 16174): Trucha Bug, NAND Access IOS53 (rev 5663): No Patches IOS55 (rev 5663): No Patches IOS56 (rev 5662): No Patches IOS57 (rev 5919): No Patches IOS58 (rev 6176): USB 2.0 IOS60 (rev 16174): Trucha Bug, NAND Access IOS61 (rev 5662): No Patches IOS70 (rev 16174): Trucha Bug, NAND Access IOS80 (rev 16174): Trucha Bug, NAND Access IOS90 (rev 54321): Trucha Bug IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0 IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0 IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0 IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0 IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0 IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0 IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0 IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0 IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0 IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0 IOS254 (rev 65281): BootMii BC v6 MIOS v10
    Report generated on 2012/07/28. Report generated on 2012/07/28.
    So ... Please !?
    Rookie
  • Rookiepno
    • Jul 2012
    • 4
    And now a readable sysCheck ...
    Region: PAL
    Hollywood v0x21
    Boot2 v5
    Found 98 titles.
    BC v6
    MIOS v10
    • happy_highlander
      • 3535
      Syscheck is fine but usb loader gx v3 I find very buggy. Gx 2.3 is much more stable for me, remove all traces of v3 and install 2.3 (249) you can find it in the downloads section
      • Keithuk
        • 2264
        Welcome to DK.
        Now that you've worked out how to post a sysCheck report as instructed in sysCheck it looks ok.
        There is a newer version of Homebrew out but that shouldn't make any difference.
        I don't find the newer GX v3.0 buggy everything works on my system.
        If you want the earlier version download it from USB Loader GX 2.3
        If no games are loaded or recognised on the drive then is this drive compatible?
        Keith
        2010 Golf GTD (170)
        • happy_highlander
          • 3535
          I think I may have realized your problem. If you have selected to have partial nand emulation for game saves the games will will not load unless there is already a save file on the hdd, this is a bug that was fixed in 2.3 but has come back in v3 (like I said keith, you don't use emu so won't have noticed any bugs) this usually throws up "disc is not recognized" in white across the screen though. I won't go through the process of getting emu working again unless you get back to say that is definitely the problem
          • Rookiepno
            • Jul 2012
            • 4
            Thanks for the very quick response !
            Tried the above method to downgrade
            USB Loader GX and still the same result.
            So ... tried WiiLoader ... same result
            So ... tried CFG Loader ... same result
            Conclusion ... monday I'm going to buy an other USB Drive.
            This time not a Lacie Rikiki but something external powered.
            I get back with some results on monday ...
            Anyway ... thanks very much for trying to help !!
            • happy_highlander
              • 3535
              Most usb powered drives are very unpredictable, we always recommend mains powered for better compatibility
              • Rookiepno
                • Jul 2012
                • 4
                Hey Pro's !!
                Well well well ...
                Who could know that I made the most fundamental mistake ever.
                Just Installed an external powerd USB2.0 Hard drive ...
                Formated it to FAT32 with a downloaded program - Win 7 does'nt have a real FAT32 format app. ...
                Installed the backup's on it ...
                And ...
                (Shouting!) YES, IT WORKS PERFECTLY !!!
                So ....
                Many, many, many thanks for putting my nose in the correct direction !!
                Newbie Rookie
                • Keithuk
                  • 2264
                  Well well well ...
                  Its the simple things that catch you out.
                  Windows won't format large drives FAT32 you need to use EASEUS Partition Master it free.
                  I'm glad we have another satisfied user.
                  Keith
                  2010 Golf GTD (170)
