Cant get rid of 002 error on new games
  • weewood
    • 23
    I have started to get the 002 error on new games, such as Madworld and Sonic Black Knight.
    I have tried the fixes listed everywhere. From the IOS 38 53 55 WADs to new loaders with the forced 60 setup and the 002 fix included... nothing seems to work.
    Can anyone point me in the right direction?
    Lee
  • dell_xps
    • 2558
    Lee
    What loader are you using m8 ?
    Have you installed Custom IOS36 rev 07 as this was brought out for that error, also another option is to load it through Gecko 1.7, give these a try Lee.
    Dell.
    • weewood
      • 23
      When I try to load IOS 36 it comes up with error (ret = -1) and then asks me to restart.
      I will search for Gecko 1.7
      Cheers
      Lee
      • dell_xps
        • 2558
        Cheers
        Lee
        You dont have any gamecube save cards in your wii or gamecube controllers do you ?
        They cause problems when installing stuff.
        • dell_xps
          • 2558
          GeckoOS002fixv3.zip
          Try this Gecko with the 002 fix m8.
          • weewood
            • 23
            Sorry for not replying Dell.
            No I dont have any saves or controllers in their. Never had any problems with anything before and done, maybe 10 or 12 of these. Its just these 2 new games, all the rest are fine
            I'll try this later..
            Once again, its much appreciated
            Lee
            • Phillhere
              • Mar 2009
              • 8
              Exactly the same here....except am not using a loader....
              Wii is hard modded, and have never had any major problems.
              The blank screen/WII lockup occurs by selecting the disc in disc channel, and I too get the 002 error when trying to load using gecko.(not sure which version..)
              Except for a similar problem with SSBB,( blank screen after launch,) I havent seen this before but that was settled easily by changing to 50Hz.
              This has been a real pain, have tried loads of things before happening on this thread...
              next up the gecko os as suggested, will let you know..
              Will I still need to do the cIOS 36 rev 8 update as suggested in a lot of places...
              • dell_xps
                • 2558
                Are you using Gecko via the homebrew channel, and are you using the version I've posted above with the 002 fix?
                • thelips
                  • 84
                  i just tried madworld and it works fine on 3.2 with oo2 fix still waiting for sonic to dl let u know how i get on with it
                  • dell_xps
                    • 2558
                    Cheers for the info lips !!!
                    • Phillhere
                      • Mar 2009
                      • 8
                      "Are you using Gecko via the homebrew channel, and are you using the version I've posted above with the 002 fix? "
                      yes, but its an older version...
                      so am going to try the one you listed tonite.
                      and just my luck.. in fiddling around trying to get this solved, I turned off update protection and this morning there was the blue pulse of doom from the console... updated to a fabulous 3.4e... so now i need to sort that out too...
                      I am assuming as homebrew was already up and running this wont have screwed it up...but if so , then thats another setback...
                      grrr
                      • dell_xps
                        • 2558
                        grrr
                        Still runs on 3.4E.
                        • Phillhere
                          • Mar 2009
                          • 8
                          cheers for the tip.... saves me having to drop it back, and more chance of screwing something up...
                          Phill
                          • weewood
                            • 23
                            Dell,
                            Do I just drop these files in to the WAD folder then run WAD manager from HB?
                            Lee
                            • weewood
                              • 23
                              Thanks everyone for their help. Managed to fix the problem by loading the Zelda Force NTSC Backup WAD.
                              Now both Mad World and Sonic Black Knight work
                              Cheers
                              Lee
